Question about NorStar Maestro 1500 Corded Phone
Almost every night between 11:10 pm - 11:15 pm the light that signals line in use etc, will come on for 1 - 5 sec and then go off. No one is on the line. What is happening. I cannot change any batteries and I have unplugged the phone and then plugged it back in as Bell has suggested. What is happening?
I need the specs (size, height, width etc) for the GE Spacemaker XL Model#JVM1631WB 004
Specs are:
Capacity
Oven Capacity (cu. ft.): 1.6
Features
Wattage (IEC-705 Test Procedure): 1000
Cooking System: CircuWave™ Plus
Power Levels: 10
Style: Over-The-Range
Clock: Plus AM/PM pad
Electronic Scrolling Digital Display: Yes
Electronic Touch Controls: Yes
Kitchen Timer/Timer (On/Off): No/Yes
Variable Scroll Speed: 5 speeds (sub-pad w/ AM/PM)
SmartControl System - Concurrent Programming: Yes
SmartControl System - Help Pad: Yes
Beverage (Convenience): Yes
Cook (Convenience): 9 Codes
Popcorn (Convenience): Yes
Reheat (Convenience): 6 codes
Add 30 Seconds: Instant-On
Child Lock: Yes
Cooking Complete Reminder: Yes
Defrost Type: Auto & Time
Delay Start: Yes
Display On/Off: sub-pad w/ zero
Express Cook: Instant-on 1-6
Reminder (24 hr): Yes
Time Cook: I & II
Time Preference: Control Enhancement (1/9)
Turntable: Glass
Turntable On/Off: Yes
Turntable Size (in.): 13-1/2
Cooktop Lighting: Bright/Night/Off
Night Light: Auto
Rack Type: Wire Oven Rack
Sound Volume Control: 4 levels
Easy Mount Installation: Yes
Exhaust Fan: 2-Speed
Appearance
Case Color: Black
Color Appearance: Stainless Steel
Door Color: Black/Stainless Steel
Handle: Designer-Style
Weight And Dimensions
Approximate Shipping Weight: 63 lb
Overall Depth: 15 5/8"
Overall Height: 16 3/16"
Overall Width: 29 7/8"
Cavity (W x H x D): 20 31/32" x 9 3/8" x 14 3/16"
Power/Ratings
Electrical Input - 120V Amperage: 15
Electrical Input - 120V Watts: 1480
Frequency (MHz): 2450
May 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
No ring on lines on extension 11 and 12. How do I program to ring?
Please follow the steps given below
To set distinctive ringing
1. Press #9876 to enter User Programming Mode
2. Press a Line or extension button. The LED is steady green.
3. You can press Hold to switch between internal and external pitch.
(Internal = station calls within your system; external = outside line calls.)
4. Enter the two-digit pitch number (see table)
5. Press the same button that you pressed in Step 2 (Line or extension). Two beeps is a confirmation tone and “DATA PROGRAMMED” displays on your LCD.
Tone No.                   Frequency and Cadence
 01
     500 Hz 1 sec. On, 3 sec. Off, repeat
02           300 Hz 1 sec. On, 1 sec. Off, repeat
11          500/640 Hz 1 sec. On, 3 sec. Off, repeat
12          500/640 Hz 1 sec. On, 1 sec. Off, repeat
13           860/1180 Hz 1 sec. On, 3 sec. Off, repeat
 14         860/1180 Hz 1 sec. On, 1 sec. Off, repeat
15          1300/1780 Hz 1 sec. On, 3 sec. Off, repeat
 16         1300/1780 Hz 1 sec. On, 1 sec. Off, repeat
17          860/1180 Hz 0.5 sec. On, 1300/1780 Hz 3 sec. Off, repeat
18          860/1180 Hz 0.5 sec. On, 1300/1780 Hz 1 sec. Off, repeat
Thanx
Jul 22, 2010 | Toshiba DKT2010SD Phone
I have 3 lights and want 1 light to come on for 15 sec and then off and another 1 to come on for 15 sec and then off and then the last light to come on for 15 sec and then off and start the process all...
Intermatic 70815CR
30 amp max, selectable voltage 120V 240V etc.
You want to control 3 separate circuits.
So you need a timer with minimum of 3 independent relays.
Each circuit has a different program.
So you need a 3-channel timer. Each channel is programmed separately to operate a different relay.
You want timer to operate in 15 second intervals. Most electronic timers have minimum 1 minute on-off, so you need electronic timer with pulse capability.
May 11, 2010 | Amperite Dayton Solid State Timer On Delay...
My siemens LCD monitor back light turns off after 1 sec
You need to check out caps in the power supply section first, then check the backlight inverter circuits for bad fuse, transistors. It can also be bad lamps. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 05, 2010 | Fujitsu Siemens Siemens Basic Line B15-1...
The light on the back of my phone wont go off. it stays on when i plug it in and also any time i push ANY button it lights up
Check in the Display Settings of your handsets. There you can specify for how many Seconds you like to put ON your handset's LCD Backlight. You can customise it for 5 Sec, 10 Sec, 15 Sec, 30 Sec, 1 Minute, etc.
Apr 23, 2009 | Cell Phones
Burn fail or cd skip
Kind of sounds that way. They are pretty inexpensive now days, and simple to install.
Good luck
Mar 17, 2009 | Gateway M680X PC Notebook
Wireless router looses connection from 9:00 PM to 7:00 Am everyda
what channel are you running the access point on? The only thing i can think of is that some wireless interference starts around that time of night which wipes out your wireless sign. Changing the channel may help (but change it to some atleast 5 above or below the current setting as the channels overlap).
Matt
Feb 12, 2009 | 2wire (1000-400108-001) Router
I can't get on line
A blinking DSL light means that you have no DSL sync -- you are not receiving a digital signal. You will need to contact your ISP to have them repair your service.
Steps to do first:
1. Powercycle the modem -- unplug the power from the back for 15 secs, plug it back up.
2. Ensure that all phones that share a line with the DSL have filters attached.
Jan 28, 2008 | Westell Wirespeed LiteLine 6100...
Burn error
You unit is faulty.. replace the unit with a new one. The CD Write Laser has probably "Burnt Out" or perhaps the "Quadrant Detector" has faulted.. either way a new unit is only way solve ya problem ... sry :(
Sep 03, 2007 | HP Media Center m7250n (ED842AA) PC...
YAMAHA CRW8424 gives Track following error..
PROBLEM DEFINITION: Basically, it is a hardware error that occurs when a drive is not capable of following a data track on a CD-R or CDRW or on the other hand, poor power flow may cause the problem SOLUTION: 1. Try use another disc, a disc with a different band. 2. If one doesn't work, you may have to open your system and use a different power connector, making sure no other devices are using the power connector in the same strand. 3. Lastly, if neither the above doesn't work, you may have to send your drive in for servicing as the head may be dirty or misaligned.
Aug 05, 2007 | Yamaha CRW 8424 Burner
NorStar Maestro 1500 Corded Phone Logo
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
