I bought a rowing machine per the above details in late 2011. My daughter is a rower and when she tried the rowing machine she stated that the tension was very high and it was extremely hard to row even on the lowest tension setting. I contacted the selling agent but they suggested that the model was second hand, wouldnt swap it and stated that I should try to sell it if I didnt like the tension. Not really helpful!! I was hoping that you might be able to offer some assistance. The actual tension mechanism is shrouded in a casing and apart from the adjustment knob, there is no other access.
SOURCE: Machine does not register when rowing
You most likely moved or damaged the senser under the seat check if the wire is loose or damaged the the senser it in the center of the bottom side of the seat Good luck
SOURCE: My friend gave me her
You may have to take it apart one section at a time take photos of this project unless IconFitness has a manual for this unit. I suggest this course of action check , clean and if needed lubricate all movable parts then reassemble unit. If you want to put in the time.
