To get an idea of why the set is shutting down when it does shut down if power light goes out do the self check this set should have.
Does the power light go out when it fails?
2 blink-then 3 blink---------deflection circuit problem.
It means something in the deflection section is not working right--deflects picture up down and left right--This may or may not be a do it yourself repair---how would you describe your skill level at electronics repair?
Going to need a volt/ohm meter and likely need to locate a schematic---With the Chassis (circuit boards in the plastic frame) up so bottom faces rear of set I would begin with a very close inspection of the bottom of the boards looking for broken solder connections, l would then do the same for the top of the boards looking for any burnt or damaged parts.
Can or cannot do?
Mitsubishi model VS-50609, serial number 121604 , made in 2001. Had a repair done earlier and they first resolver turner, where is that so I can check that, then came back and replaced IC Convorgence, 4 resisters. Where do I start from here? I have read about replace bulbs, or power supply unit is bad. Please help.
I have looked thru Manuel for self check and don't see how to do that test, how do I complete a self check?
when set goes off and power light is also out press and hold both the menu and input buttons on front of set (not the remote) for at least five seconds and let go; set's power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
If you have unplugged the set you will have to power it up and wait for it to fail to try the self check as removing power clears the error buffer.
If you find a code it may narrow down where the problem is at.
Did the self check and it does 2 blinks then 3 blinks, does this 5 times. So far you are helping 100 percent and I thank you so much.
That sounds easy to fix if I knew more about volt/ohm, who or where to call or start now? But you did great.
