1)lube the DECK BELT, you have a lack of maintenance schedule. mAYbe you have a deck belt worn. This produce enough friction between deck vs deck belt and shut down the machine for to protect the electronic system.
2) Lube the rollers bearing in according with the maintenance schedule.
3) Test the voltage input motor, if there are the motor need repair.
4) Test the output voltage board,for input voltage motor, if there are NOT the board is faulty.
5) Try to run the software calibration for diagnose, troubleshooting,etc
6) SEe my personal tips for help.
sincerely. God bless you
SOURCE: nordic track exp 1000 treadmill console
Sound like function pad or upper console I don't know if you can purchase the function pad, but you may have to purchase the entire console and that may quite expensive.
SOURCE: Treadmill won't start. Console works but when
If the console takes
batteries, replace them. If this does not work or your console does not require
batteries, check the reed switch or optic sensor. Reed Switch:
Unplug the treadmill and remove the motor hood cover. The reed switch is mounted
on the frame next to the front roller pulley. There is a magnet glued into the
front roller pulley. When adjusting the reed switch, make sure it is pointing
directly at the magnet. Move the tip of the reed switch within 1/8" of the
magnet. Also, check to see that the wire is not damaged, and is connected to
the console
Optic Sensor: Unplug the treadmill and remove the motor hood
cover. The optic disk and sensor are located either at the end of the motor or
the right hand side of the front roller. The optic disk spins between two
sensors on the optic switch. The disk must spin freely without touching either
sensor. The sensors can be moved by loosening the adjustment bolt holding the
switch to its bracket. The switch can then be slid. Center the disk.
Remember the Display Console Board has circuit that send to PController Motor, and after you did the adjustment you can conclude if the Sensor Reeed is faulty, 2) The Display of 3) The main Controller Motor.
o 1
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
o 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Cleaning: Remove the covert and spray the Key Pad with special spray( contact cleaner) for to remove dust, etc, very carefully, you mus unplugged the machine.
o 1
o 2
o 3
2. Reed Switch
o 1
o 2
o 3
o 4
o 5
Check too:Optical Sensor. If have it
