SOURCE: Why two black ink cartridges?
The larger of the two cartridges is used for text only. The smaller is used for color printing. Its purpose is to eliminate the need for a "Processed" black (black being mader by the color inks).\
Don
SOURCE: black ink cartridge is leaking and black line is running down back of page
YOU CAN TRY PULLING THE CARTRIDGE OUT AND WITH A CLEAN , VERY SOFT CLOTH , CLEAN THE HEAD GENTLY ....SOME CARTRIDGES ARE JUST FAULTY ....HAVE YOU TRIED RETURNING IT OR GOING TO CANON SITE AND TROUBLESHOOTING ?
SOURCE: cannon ink jet quit printing black
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
SOURCE: error u043 with MP610 Cannon. cyan cartridge not
This error indicate that the printer fail in detection the certain ink. The simplest one is to compare the ink tank with the good one. If this doesn't fix the problem,carriage unit or logic board might be faulty.
More information
SOURCE: Canon MP610 out of black ink
Cannon Pixma MP610 - when the black ink is empty and you receive the replace ink message, then hold down the "cancel" button for 5 seconds or so and it the printer automatically bypasses the problem. It does work but Ive had mixed success in terms of the print quality when doing this.
