Its a 2002 model ws55859 big screen projection tv by mitsubishi 52 inch Ijust got it from a friend , it worked good be for we moved it when i got it to my place and pluged it in all I got was a green flashing light on the timer I tried the reset but nothing !
I installed a v19/v21 dm repair kit thank for the help works great now....
The problem is the DM isnt completeing the boot sequence due to the failed caps. You can get the V21/V19 DM repair kit at the following link which contains the replacement capacitors and a CD with step by step instructions with pictures on how to do the repair. Heres the link.
http://servicemanuals.vstore.ca/
when i turn on the tv the green light its blinking after 60 seconds the light goes off by it self what can i do please let mi know
My 2yrs old 55' mitsubishi's led flashing 30-45 sec then shutting itself off. power supply's Capacitors are shotted per infos from many web answer searched. I'll try to replace all 4 caps. in DM module and update this problem later how it goes??? so stay tuned...
I have the same probelm. TImer light blinks and TV won't turn on. It worked fine for over 2 years and now I can't get it to turn on. Reset does not work.
