When i on my laptop then its on the green light is showing but the display is not show please tell me the solution of this problem
Is the laptop on and running but the display is black? Do you hear the fans running and the disk drive spinning, but the screen is black?
Shine a flashlight on the dark screen to see ifyou barely see the icons on the desktop. If so, then the LCD Inverter isbad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad
Seems like a faulty MOBO.Bu start problems can be a lot of other problems like a faulty RAM or VGA.I need more ifo like your OS and any that can help.
