Question about Oasis P1AQ
Oasis water cooler taps started dripping
It started dripping a few weeks ago but if you wiggle the tap handle around a bit it will stop dripping temporarily until you use it again. is it a washer or do i have to purchase a new tap or taps?( there is a cold water & a room temp. tap) is this a "do it yourself" project or is it to difficult task to try to fix on my own? thanks for any advice you can give me
    Problem Solver:
  • 12 Answers
If the cooler is a hot and cold, even if its a cook and cold, the cooler always needs to be cleaned and maintained, not only on the inside but on the outside, as the cooler is used calcium builds up over time. that is why your taps are leaking, there is a build up in the taps, therefor the taps are not sealing properly and letting some water thru. i say take the taps out and clean them with vinegar.
the second thing u can do is the taps do come apart into smaller peices once u disconnect them from the cooler. take the taps apart and find the spring located within it, stretch the spring and than reconnect the peices together than reconnect to the water cooler.
Posted on Jun 09, 2009
Just had this problem... hot was fine, cold was leaking. the rubber stopper was kinda nasty and needed to be washed, and there was a little bit of plastic residue that had made its way in between the seal and the rubber which was wicking water through drip by drip... a good cleaning... (more fun when there is a full tank on it at the time) and it's good as new, no more drip :)
Posted on Nov 21, 2009
SOURCE:
I have been have a loud vibrating almost rattling noise coming from my shower when the show head is engaged. Only when its engaged. It starts about 5-10 minutes into the shower. Does anyone have an idea of...
You may have to high a water pressure. This may have been disguised in the past by the mains tap being partially closed (deliberately). The plumber will have opened the mains tap fuuly after repairing the leak. Alternatively you have water hammer caused by loose pipework. The plumber may have removed a pipe clip in order to repair the leak.
Feb 11, 2015 | Home
Fix a quater turn mixer tap Aumix
change the cartridge...shuld help
Dec 04, 2013 | Plumbing
My delonghi perfecta plus esam5450 tells me to descale when the last descale was only 3 weeks ago. It is 18 months old and I usually only need to descale every few months. However, the last 3 times i have...
Marion, mine does the same and is around the same age. Did you ever get advice regarding this. I don't use rain water, I use tap water, but same problem
Aug 16, 2011 | Microwave Ovens
Lisbon monobloc kitchen taps just installed the
Put some cooking oil around the o-rings to sofen them up so they would seat around all fitting surfaces. Hope this helps.
Aug 12, 2010 | Home
I live in a row house built in 1942. My linen closet door wouldn't shut, but a few weeks ago I forced the issue. It shut, but now I cannot get it up. Someone suggested taking the pins out of the hinges....
Hi Margaret. If you can post a picture that would be immensely useful. From your description I'd suggest you don't force it further because it is usually easy to damage the woodwork and/or the hinge. If you can get the screws out of the handle then a bit of wiggle and *gentle* force, may free what seems to be 'glued' in place. Tapping on the underside with the tip of a flat blade screwdriver may help.
Jun 15, 2010 | Hardware & Accessories
Water leaking (dripping) into the drum when machine is off. Drip is coming from where water dispenses into the machine to fill the drum.
Hi just read your posting.The fault with your machine is a faulty water valve.1st turn off the cold tap to the machine and leave for a couple of hrs.If the dripping stops you have a faulty cold valve.If the dripping does not stop then turn off the hot tap and that should stop the leak.Either way to fix this fault a water valve must be replaced.Or you can stop the drip by just turning the taps off after the washing has finished.Hope this helps and please reply for further help if needed.
Jun 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Tried to tighten hot water tap to stop a drip and
There is normally a plastic washer at the end of the valve stem which you turn to allow the water to flow and to stop the flow. It sounds like this washer has either deteriorated or been damaged by over-tightening. You will need to remove the stem and replace this washer. It is normally held in place with a screw.
You will need to remove the on-off handle and probably a stem cover to access the flats on the stem where you can place a wrench. These flats will likely be recessed into the shower wall; therefore, it will likely require a deep socket to reach them. Most hardware stores will have the sockets needed to remove and replace these stems.
Of course, make sure that the main house shutoff valve is closed before you start to do this.
Apr 20, 2010 | Home
When I turn on the cold water tap in the Bathroom Sink the water comes out in a very slow drip or not at all, the CW bath tap is ok
Confirm that the shut-off valve under the sink is open all the way. If it is, then close it and remove the cold water tap. If this is a single handle tap you will of course have to turn off the hot water shut off under the sink too.
With the tap removed and a bucket and towel handy, open the cold water shutoff just a little bit. If water comes rushing out, the problem is obviously with the tap. You may be able to clean or repair it, or you may have to replace it.
Mar 19, 2010 | Home
Oasis P1AQ Logo
2,269 people viewed this question
Top Oasis Refrigerators Experts
Marvin
Marvin
Gil Shultz
Are you an Oasis Refrigerator Expert? Answer questions, earn points and help others
