Nintendo Guitar Hero Wireless Guitar - Wii for Wii Logo
Posted on Nov 14, 2008
Wont power up, blue lights stay on have changed out the batteries
Have changed out batteries numerous times, cheap, good and rechargeable batteries.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
303
Points
Try resetting the remote and the console. in the console you open front panel and their is a red reset button press this firmly then remove batteries from back of remote press the reset on the console again. Then replace the batteries press the red reset on the console a third time and then push the red reset button on the back of the wii remote this should take care jof your problem.
Big blue speaker repair
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
If the speaker is under warranty get it replaced.
Taking the speaker apart to replace the battery will compromise or even destroy the acoustic properties of the speakers. Big Blue Live Wireless Bluetooth Speaker
Can't charge motorolla talkabout T6500 battery
Hi treva,
These little radios are are real problem when it comes to batteries.
Not only do they eat batteries, but due to requires numerous recharging, you soon burn the poor batteries out.
Motorola is a great brand, unfortunately these little radios are made in great mass under license in good old China for a cheap price, and in there lies the problem....
You only get what you pay for...
Cheap & nasty.
I have answered numerous queries regarding this very problem with these battery munchers.
Sorry that I can't give you a real solution, but if you pay peanuts, you get monkeys.
Best advice is to buy a good 5 watt CB radio on ebay with charger, they're reasonably priced and if something goes amiss, there are definate fixes for them.
Sorry I could not give any other solution.
Cheers,
Peter
1helpful
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Battery power to car went dead dsc and brake warning light and flat tire monitor lights stay on i recharged the battery now have power but lights are still on
You will have to get the computer reset. Auto Zone used to do it but now they wont. Some shops do it cheap. Or try Auto Zone and see if they will do it for free.
2006 dodge durange wont start tried to recharge
Some times battery's are beon recharging that recharge wont do it, after you recharge battery turn your lights on, if very dim or dont come on, battery is no good replace it, also try to start it it if lights go off, replace battery.
1helpful
Craftsman power drill - batteries wont recharge. When I insert dead batteries into the charger The green light ''Fully charged'' comes on and stays on. The batteries do not charge as when they are inserted...
the battery's are most likely dead, (like the real dead) after many uses of rechargeable battery's they slow stop holding charge at all, make sure when you get a new rechargeable battery you fully charge it once and fully discharge it once this will increase batterys life time
Sep 27, 2009 • Drills
Battery light stays on
the battery light has nothing to do with the battery itself, it is indicating that there is a problem with the alternator that charges the battery, most likely a defective rectifier bridge diode has failed.
5answers
WONT STAY ON
check your batteries...sometimes cheap batterie or regular batteries do the same to mine...you may need to spend the little extra and purchase batteries for a digital camera ect....good luck
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
