Disney D7000PD Portable DVD Player Logo
Keith Easton Posted on Apr 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Portable DVD Player Won't Work
Can't get the player to work. Switched out DVD's, still won't work.
Anonymous
Level 3:
  • Disney Master 6,771 Answers
  • Posted on Apr 18, 2012
Anonymous
Disney Master
Level 3:
Answers
6771
Questions
0
Helped
1777254
Points
21413
The laser pickup assembly has failed, to replace the part will be more than it is worth. Far cheaper to replace the player.
4 Related Answers
Robert Billyard
  • 277 Answers
  • Posted on Jul 25, 2010
SOURCE: Disney D7500PDD Portable DVD Player doesnt spin DVD
Very Good Daniel,
if you are good with a srewdriver.. you could use a DVD from a computer and swap it to disney
Does the door to DVD slides out or pop the lid.
You still can swap if you are careful and you know what you are doing
I've done a few times.
Let me know in the future, if you can't, you can send to me for repair
GG TECHNOLOGIES
  • 201 Answers
  • Posted on May 15, 2011
SOURCE: Our little girl's pink Disney
INSERT A LONG NEEDLE IN THE HOLE NEAR THE CD TRAY AND SIMULTANEOUSLY PRESS THE EJECT BUTTON. PLS REPLY OR COMMENT. THANKS
Kenneth Lee Sr.
  • 597 Answers
  • Posted on Jun 10, 2011
SOURCE: player sticks and won't play.
Buy a lens cleaner...about $10-$15
Anonymous
  • Posted on Nov 27, 2011
SOURCE: why doesn't the lion king dvd work on my dvd player
Idk but im having same issue my guess is manufactured wrong or store has bad batch but works perfect on pc...
1helpful
I have a sony DVP-FX74 portable dvd player that won't turn on. I have charged the battery. Any ideas?
the power system has been interfered with,i won't use a complicated language but i need you to try and use an adapter,if it doesn't work it means the transformer has a problem or it has failed completely and it needs replacement
Portable DVD player won't work
Try clean lens or change the CD hope it will work.
Does not spin dvd
Sometimes the brushless motor driver circuit fails. Rarely does the motor itself go bad. On some models, if the the laser diode is too weak to read the disc, the player will not bother to spin it. It won't spin so a lens cleaner disc won't work You can try to take it apart and clean the tiny lens. Don't use alcohol. Windex and a Q-tip works great to remove grease and dirt. Don't buff it hard. Just wipe lightly a few times and look at it at an angle to make sure it is shiny, not hazy. Almost all of these are not an economically viable repair. If cleaning the lens does not help, you are looking at another portable player.
2answers
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
My philps Dvd player won't work correctly
From the description the pladder motor is bad, " disc spins on" or it is missing the 5 volts that drives the motor. The laser pickup that pops up and down appears to be working fine.
My Toshiba SDP93S portable DVD player won't work.
The power supply adapter may be dead, should be tested, if okay! remove the main battery will load player down in some cases. If still no result! cheaper to replace than repair.
Sony portable DVD player dvp-fx970 won't play dvd
Use lens cleaner TDK or wash dvd disks with hot tap water then block off the water drops.
Top Disney Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
