Dell 3100cn Laser Printer Logo
Posted on Nov 14, 2008
LDell 3100cn awer printer won't recognize new toner
I Have changed the black carteridge on my Dell 3100 cn laser printer but the machine won't recognize the new cartridge and generates a "replace toner" error. I have 1, reseated the cartridge, 2 cycled the power on the machine, 3 reset the nvram, 4 cleaned out the toner housing area. All to no result. How might I fix this?
  • coyboss Nov 24, 2008
    I have tried 4 brand new Black toner cartridges and it keeps telling me to insert black toner.
    Its almost like after it finishes calibrating it doesn't see there is a cartridge installed. It does show 80% black toner while calibrating (from the Browser interface), but when it finishes claibrating and starts to print it gives the insert toner message!!!
    HELP
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 25, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
525
Points
Have you removed the plastic protection strip from the bottom of the toner?
1/2" white line appearing down right side of page
Try replacing the toner cartridge. This seems to be a problem with the photo-sensitive drum, which is located in the cartridge.
1helpful
I have a new Dell 3130 cn printer. For the past
Sounds like the drum unit is damaged. Replace it. I mean not only the toner unit but the whole thing. Remember never touching these...
Hello My printer(3100 cn dell) every time I
This means that loose toner powder has gotten in the way of the lazer "eye". If you open up the front door, you will see a blue tab toward the right, pull that toward you, then look on the right side of the printer, you will see that a door has opened. Pull that blue stick out as far as you can and you will see some toner powder on that, clear it off, and make sure the little pad is clean. After you have cleared the powder off, slide it back in and out a few times, this will clean the eye. Run another document through, if the line is still there, just clean another time. Should go away. I have this problem alot.
Dell 3100 CN Prints a stip on black all the way
There is a known issue for these printers to "streak." If under warranty, call Dell. If not, there is a fix
for the defective drum unit design but requires a little technical expertise.
The procedure is explained here:
http://www.ahfx.net/weblog/133
Hi, My Dell 3100CN printer is displaying "Change Black Toner." I have replaced the toner cartridge. The printer begins to calibrate for a very long time. When it finally finished calibrating, it return to...
There is a chip in each toner cartridge which tells the main machine something about how full it is. It may be that it tells it how full it is, or it may be that it tells it how many pages it has done. It sounds as if the new black cartridge has a duff chip, and is telling the main machine that it is empty. To test this, you can overide the message. 1. press on the menu button;
2. select configure;
3. select maintenance;
4. select non-dell toner;
5. set the value to on.
If that does't work, get back to me.
Tony Ludlow
Not recognizing toner
Shake the toner cartridges.
Make sure the connections that are on the printer for the cartridges are clean.
Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Linux printing with Dell 3100CN
OP provides the solution! (BTW, I'm able to print to this printer from MacOS too.)
Dell 3100 printer ghosting
Ghosting can be caused by two things. Either too much toner is being laid down which incurs a starvation of it. Or, the image is being repeated due to a problem with the drum. In your case, I want it to be the "too much toner" deal, because a drum replacement can definitely be more costly in comparison to a design change. Yet, if it is under warranty, the drum will be replaced at no cost.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
