SOURCE: Power indicator light blinking
it looks like the battery is defective. try reseat the battery while the power cord plug in to see if that help. if you remove the battery and leave the power cord plug in, the battery symbol indicator light will turn off. Time to order a replacement battery.
SOURCE: Dell e1705 will not charge battery any longer
The problem with your laptop unfourtunately is not anything you can simply waive your wallet at, There area on the laptop where you plug in the power Adapter has a very small connector on the inside, this connector because of the nature of the cable and being pulled around and adjusted constantly causes the solder that hold the DC connection in place becomes damaged, sometimes if held in the right position it will charge, but this will only work for so long as the connector becomes more damaged by doing so. Your options are to A.) take the laptop to someone who can solder it back on (literally takes 25-30 minutes) but finding people who are willing to do it is not so easy, i recommend smaller computer shops with Uber nerds (look for the dude with the calculator watch) Option B.) this actually is something that dell covers under warranty as its not damage done by you directly, the damage is done with general use. I would at least try to contact them to see where you are with your warranty. C.) Call Dell's Spare Parts department in the event that your laptop is not in warranty and purchase a motherboard replacement ( seems extreme but its the only way to replace that proprietary connector without soldering it back on ). There is one more problem that could cause this, and that is that the motherboard in your computer has actually started to fail and is not getting the power to the battery, in which case you Have to contact dell, or find someone who will replace the motherboard for you most likely at an hourly rate. if this is the case Go hunting for Dell E1705's with broken LCD's for sale, you will save your self a ton of money, and swapping the motherboards out is really not that difficult, any computer repair place should have the ability.
This solution addresses all the known problems I've seen and should get you on the right path.
Good luck! Stay Classy :)
SOURCE: Dell Inspiron E1705 Do I have a switch or
you should have software that came with Dell but failing that you can use Windows by clicking connect to on the Start Menu
SOURCE: dell inspiron 8000 without operating system
First, if you are still running Vista on your desktop then you will need to buy a license for the laptop. Does the laptop have a WinXP on it now? If so, go here http://www.microsoft.com/windows/windows-vista/get/upgrade-advisor.aspx and run the Vista Upgrade Advisor. If not, determine the hardware specifications of your laptop and go here http://www.microsoft.com/windows/windows-vista/get/system-requirements.aspx Compare your laptops specs to those listed for the version of Vista you wish to install.
SOURCE: Dell Latitude D510 fails to power up
the battery can be shorted so that parts or the unit may have problems in
