There is no problem in your phone but the pc has problem open my computer and then go to device manager in properties select universal bus root hub uninstal the two point zero version
Is it pluged direct to the main USB plugs or through another product if it's a pc plug it in the back main USB ports and it should work and also check your settings on your mobile phone
SOURCE: Driver software
please try this out in other systenm and see of the problem is with the USB port of ur system
SOURCE: Can't figure out how to connect mini-usb device via bluetooth to
find motorola user guide it at
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/W377g_UG_.pdf
this is for w376 and w377 user guide
