If the lower drive of your Ryobi weed eater has broken off about an inch, it may be possible to repair it. However, the extent of the damage and the specific model of your weed eater can affect the repairability. Here are a few steps you can take to assess the situation:
1. Examine the broken piece: Carefully inspect the broken lower drive and determine if it can be reattached or if it requires replacement. Look for any other damaged components as well.
2. Check for replacement parts: Visit the official Ryobi website or contact their customer support to check if they offer replacement parts for your specific model. If the broken lower drive is available as a separate part, you can order it and replace the damaged one.
Easy, just hook up old drive as secondary and new drive as primary. Copy what you need from the secondary onto the primary. When you are done, just disconnect the secondary drive and enjoy your new one.
Hi John, not sure from your description which light you refer to.
But this sounds like your drive has either had a read / write issue - in which case you need to run a new cleaning tape through the unit and then retry using a brand new data tape - OR it has had a damaged tape loaded into it which has now broken the tape drive.
If the drive has been broken then try contacting www.tape-drive-repair.com who can repair or replace it for you and also look at
From my experience, it is not even close to cost effective to try and repair a hard drive with a broken pin. A new enclosure/board would have to be purchased and that board would have to be a match to the one you are pulling for the hard drive to be usable. This all needs to be done in a clean room.
It would cost hundreds less to just replace the drive.
Backup, backup, backup, and then when you are done with that backup again.
Try right clicking on My Computer
then click manage.
Under disk management your drive should show up.
if not it might be in need of repair.
There are many ways to repair it most non DIY.
It might be broken because the case connections are broken so you could try and get a new external hard drive case.
You would need to find a new connector to replace the broken one - a very difficult task since they are not sold as parts. Just replace it and save yourself the hassle.
I have fixed many broken connectors, sometimes they are simple, other times they are tricky ( a broken connector can sometimes take part of the Printed Circuit Board with it ) and require very delicate skill. If the problem looks obvious you could attempt a repair. If the data is important and you need it, send it to a professional data recovery service. Believe it or not solder in the wrong places can seriously damage the chances of a successful recovery. I now run a simple mail in recovery service http://happydatarecovery.com/ , mail your drive in and get the data back.
if the broken piece is internal and rattling around, it is most likely terminal and you need to replace the hard drive, if it is an external part or a connector you may try a computer shop to see if it can be repaired, but more than likely that will cost more than replacing the drive, but they may be able to recover any data that is on it
