The print window says (yellow triangle exclamation mark) "Ink/toner waste bin full! marker-waste-full-warning but I just replaced that waste box and it should not be full. What should I do?
The clear section of the waste toner box where that goes inside the machine check that area sensor located there might have toner on it so the printer thinks the waste toner box is full
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: konica minolta opc drum magicolor
When you print stop the printer half way through then check the image on the opc drum and transfer belt to see if it's complete or not, also you may want to check the aidc sensor (sometimes the cable comes loose). I can e mail you the 2300 series service manual (4.17mb) if you reply with your e mail address
SOURCE: Konica Minolta magicolor 5440 DL
Make sure the drum is working correctly. It could also be that the electrical current is not applied to the drum in the printing process causing the toner to fade. Try cleaning the printer heads manually. Hope this helps!
SOURCE: REPLACING CARTRIDGE
You should be able to replace just the needed color. Select menu, arrow right until "Engine" is displayed, select, select "Replace Toner" select color cartridge desired. follow directions on screen.
SOURCE: printing ghost images (shawdowing)
You'll have to align the print cartridges. You should be able to do this with the software that was installed with your printer. Hope this helps.
