Mitsubishi WS-65908 TV Logo
John Scalia Posted on Apr 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi tv ws65908 troubleshooting
Double vision with red and blue separation
Anonymous
Level 3:
Top Expert:
  • Mitsubishi Master 14,553 Answers
  • Posted on Apr 17, 2012
Anonymous
Mitsubishi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715599
Points
48227
Convergence and is fixable.
My RCA HD52W59 HDTV Television has double vision and red, green and blue colors separated like a spectrum in stead of all the colors blending together to make one uniform picture. What can I do?
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
KP-46WT510 Red lines and double vision
yes the convergence problem leaves a shadow of red or blue like an outline around the picture, sometimes part of the screen some times the entire screen.
2helpful
Blurry screen double vision picture
The convergence circuit has failed. It is not a easy fix due to the tear down needed to get to the circuit area. I would call Mitsubishi at 18003322119 to get a Authorized Service Facility to check it out and give you a estimate of repair cost.
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Trying to use my tv as a moniter
If you still have the pc monitor pluged and want to use the tv as an exetended desktop
you have to activate the second monitor in the - control panel - Display - settings
Seeing red on my screen and doubke vision
Could be a problem with the convergence IC's or a resistor(s) / capacitor(s) around the IC's.
I suggest calling a service guy and getting the TV fixed.
Double vision on my samsung HDTV 1080i
If one or more of the colors, red, green or blue have separated from each other and you can`t correct the problem using the convergence procedure as described in the users manual, that would indicate you have a convergence problem. Bad solder connections on the convergence output chips are common. If the set had a rough ride down the stairs while moving, that may have facilitated in exposing a preexisting condition. However, the most likely cause is the natural failure of one of the convergence output chips and or related components and not the move. The fix is to have a qualified technician address the problem. This is not a do it yourself job.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
