HP Pavilion Elite m9500f  PC Desktop Logo
Posted on Apr 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error Code BIOHD-4
I am getting this message message when I turn my computer on: "Unitialized/corrupt boot structure detected." How can I fix this problem--hopefully without deleting any data? I do not have a "repair disk" but have access to another computer if there is a website where I can create one. If it matters, I am using Windows Vista. I am pretty new to this so please be as specific as you can. Thank you!!!
Brian Sullivan
Level 3:
  • HP Master 27,725 Answers
  • Posted on Apr 17, 2012
Brian Sullivan
HP Master
Level 3:
Answers
27725
Questions
Helped
5664388
Points
79191
Remove any external devices connected to the computer except the mouse and keyboard to check if it boots normally.
This error can usually be fixed by following the steps below. Doing all this requires a certain level of computer skills. You know yourself best and whether taking the machine to a competent local computer tech (not a BigComputerStore/GeekSquad type of place) is the better solution for you.
1. Log into another user account with administrative privileges. If you neglected to make an extra administrative account do Steps 2-3. Otherwise continue at Step 4. Also see the general information about setting up user accounts in Vista at the end of this post.
2. Boot into Safe Mode. Do this by repeatedly tapping the F8 key as the computer is starting up. This will get you to the right menu where you can use your arrow key to select Safe Mode [enter]. The built-in Administrator account is disabled by default in Vista. However, if no other administrative accounts exist on the system it may be enabled. If it is, you will see an icon for Administrator on the Welcome Screen in Safe Mode. Log into Administrator.
3. If If you don't see the icon for the Administrator account in Safe Mode, then the built-in Administrator account is still disabled and you'll need to do some more work. If you have a Vista installation DVD (not a recovery DVD) you can boot the system with it. Select the default language, then choose "Repair your computer". Then select "Command Prompt". At the command prompt type:
net user administrator /active:yes [enter]
[Note: Do not type the brackets!]
If you don't have a Vista installation DVD (only have a recovery disc), the computer mftr. may have given you the Vista System Repair option (not a System Recovery!) on the diagnostic menu. This diagnostic menu is the same one where you can choose Safe Mode. Or you can make a bootable Vista Repair DVD from the file at this link:
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
which will cost you $9.75
Note: All the Neosmart recovery disc downloads are torrent files. There is a good explanation of torrent files at the Neosmart website. You will need a torrent client such as muTorrent to get the files. The torrent client will download the .iso file with which to create the bootable DVD. You will need third-party burning software such as Nero, Roxio, or the free ImgBurn (www.imgburn.com ) to burn the .iso as an image, not as data.
Now remove the rescue CD/DVD you made, reboot the system into Windows, and log into the built-in Administrator account you enabled.
4. Try a System Restore to when things were working. If you can log into your own user account, you're finished. Otherwise continue at Step 5.
5. The critical files are under %systemdrive%\users\user-account\ntuser. The ntuser.dat file is actually a registry hive. Run Regedit elevated and select HKEY_USERS and "load hive" from the menu. Now navigate to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
There is one line for each profile. If a profile is bad, check:
a) That the key name doesn't end in ".bak" (remove .bak if there)
b) That the RefCount value is 0 (change it if different)
c) That the State value is 0 (change if different)
Make any necessary changes, close Regedit and try to log in as that user.
6. If that doesn't fix your profile, it is corrupted. At that point you should make a new Standard user account and copy your data to it. Do not delete the old account until you have retrieved the data you need!
Once everything is working, log into the extra administrative account you will make per the suggestions below and disable the built-in Administrator account again for security purposes:
Start Orb>Search box>type: cmd
When cmd appears in Results above, right-click it and choose "Run as administrator" [OK]. Now you will get the command prompt. At the command prompt type:
net user administrator /active:no [enter]
Exit the command prompt.
General Recommendations For Setting Up Users In Vista
You absolutely do not want to have only one user account. Like XP and all other modern operating systems, Vista is a multi-user operating system with built-in system accounts such as Administrator, Default, and Guest. These accounts should be left alone as they are part of the operating system structure.
You particularly don't want only one user account with administrative privileges on Vista because the built-in Administrator account (normally only used in emergencies) is disabled by default. If you're running as Administrator for your daily work and that account gets corrupted, things will be Difficult. It isn't impossible to activate the built-in Administrator to rescue things, but it may be more work than you want to do. Best not to get into a bad situation to begin with.
The user account that is for your daily work should be a Standard user, with the extra administrative user (call it something like "CompAdmin" or "Tech" or the like) only there for elevation purposes. Running as a Standard user is best practice for security purposes and will help protect your computer from infection. After you create "CompAdmin", log into it and change your regular user account to Standard. Then log back into your regular account.
2 Related Answers
Anonymous
  • 240 Answers
  • Posted on Mar 20, 2009
SOURCE: windows doesnt start
you need to restore your boot system by booting from windows installation disk.
whenyou boot fron CD and ask for repair , select install windows
after you accept the disclaimer by pressing F8, installation will search for current windows installation
after the search select RESTORE
thinktech09
Andrew Chrostek
  • 187 Answers
  • Posted on Jun 11, 2010
SOURCE: error unitialized corrupt boot structure detected
try repairing the file system using chkdsk with /f switch. However, it is strongly recommended to run this tool only if you have a full data backup
. To do so, click \'Start\' and then \'Run\'. You can then type \'chkdsk /f <drive name>\' in the \'Open\' box and click OK. Here, the drive name should be exactly what is appearing in error message. Alternatively, you can opt for deleting the corrupt partition provided the backup is available. If no good backup exists, you should consider to use a Windows Data Recovery utility. These are powerful and valid Windows partition recovery utilities built to scan the corrupt or deleted partitions and safely recover the lost data. The applications are easy to install and use.
What does error codeBIOHD-* mean
codeBIOHD-* that is some hum-dinger of code.
wow.
what PC do you have HP model what?
what OS does it run?
what are you doing with the PC at the moment of error
that error means corrupted boot structures on HDD
  1. the HDD is bad, as most are that old.
  2. the OS is corrupted from virus infections.
  3. the coin cell battery is dead and now tries to boot to the WRONG DRIVE.
  4. In a real shop, we check the coin voltage and if bad we replace it then we fully test he HDD. as most are dead this old.
https://appuals.com/how-to-fix-error-code-biohd-4-on-hp-computer/
BIOHD-4/-3 Error
your BIOS is bad, sorry to say... but if the BIOS is glitchy the PC will never run right...tray to talk with an HP Tech...
5helpful
2answers
Computer won't boot, reading BIOHD-2 error code.
There are 3 step to repair biohd 2 error
If you got biohd 2 error then there is a 94% chance that your computer has registry problems. To repair biohd 2 error you need to follow the steps below:
* Step 1 - Download a biohd 2 error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair biohd 2 error.
Unitialized corrupt boot structure files detected
The core of windows is corrupted - this can't be fixed, you must reinstall it.
Error unitialized corrupt boot structure detected biohd-4 boot path, keep getting this after trying to install windows 7, cant boot disk anymore so cant install windows 7
Unitialized corrupt boot structure detected biohd-4 boot path
Apps like Acronis Disk Director Suite and Partition Magic
that might help because they can be booted outside the OS. Sometimes it just cannot be done without destroying the data on the drive. Try one of those!
3helpful
2answers
HP a6541.uk wont boot get error code BIOHD-4 cannot get it to wwork in safe mode look like boot secotor of disk is corrupted or unitialized how do i get this sorted i,m am running windows vista
goto the recovery console this should help
http://support.microsoft.com/kb/927392 get you there.
Then type /fixboot that will fix the boot sector but this can also be cause by a bad enviroment varible and you will need to either roll back the registry or get into windows to fix that.
8helpful
3answers
Error code:BIOHD-8
Rebooting forever is either memory fault or the HDD have corrupt system files. From the BIOHD-8, it sounds like HDD issue. Try download "HDD Regenerator 1.51" CD ISO, burn to DC and scan to whole Harddrive. This nice software is designed to recover corrupt/bad sectors. I had a friends PC falls into this case. 1 bad sector was found and recovered within 2GB from start where most Windows system files are stored. Then reboot and windows do a chkdsk automatically, and resolved!
1helpful
2answers
Windows doesnt start
Boot Sector Error
Can you get it to boot without the BSOD? If the problem is intermittent, it's probably a flaky drive sector. If Windows will boot, you should be able to get Norton to make a good copy.
If it will no longer boot, the sector is probably corrupted. You can tell Norton to do a sector copy & ignore errors, but that may duplicate the problem.
You may want to try what's listed here:
Look under /FixMBR. You could ghost it to another drive, then try that.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
