Question about Canon PIXMA MP600 all-In-One InkJet Printer
Scanner doesn't scan or transmit document to pc
I've had the mp600 for 1 year and have scanned about 3 documents in the past with no problem. Today, I have tried numerous times to scan the document and the printer/scanner is not responding. Initially, every time I pressed the scan button, my laptop would open a program called MuVee Producer and a message would appear on my laptop screen to say that " another user is using muvee producer...try again later." That drove me insane so I uninstalled that software. I turned my printer off and tried to scan again. It sounded as if it was scanning, but nothing resulted. The printer/scanner is still presenting the 'scan document ' screen. Can you help me out please.
thx
Lois
  • 3 more comments
  • Anonymous Nov 15, 2008
    It just says that the printer can't work but there is no communication but sometime it works right. But after about 2 scans it's done. A window pops up saying that there is no communication. I want to know if it's my printer or if it is the company in general cause it's my third Canon printer.
  • DVitry Nov 15, 2008
    Similar problem. All the buttons work but when I try to scan the black and color buttons do not work (they work fine to copy). I do not get a communication error just no reaction to pressing the button. I have reset the settings, unplugged everything etc, and nothing.
  • sevenffive Nov 17, 2008
    the go button just do not respond.
  • stupidjunior Dec 02, 2008
    I have the same problem. I have been using my MP600 for almost 2 years without a problem. A few days ago, I upgrade to a new PC and loaded new drivers from Canon's website. Everytime I try to scan a document, the scan button opens up a program called Muvee Auto Producer.
  • laurahamilto Dec 07, 2008
    The color and black button open a program called Muvee Auto Producer. I have not had problems in the past and reinstalling the drivers did not help
My printer does the same. And it's my third Canon printer and ever time when I try to scan a picture or etc. it just ends up saying that the printer can't communicate or that it's shut off. :(
Posted on Nov 15, 2008
SOURCE:
I have an HP Officejet 6500 wireless printer. If I scan or copy a document through the feeder the scanned or copied document has vertical lines from top to bottom. If I lay the document on the glass and...
Lift the scanner top, then look at the narrow pane of glass. There probably is a spek of dust or ink on it. Clean it with alcohol. I've had to remove the glass, due to the speck being on the undersaide of the glass.
Also, lift the ADF cover and clan the rollers with a damp cloth.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 17, 2011 | HP Officejet 6500 Wireless All-in-One...
Im trying to scan a document but its saying error code 2106. i have it hooked up through wireless
Try these things:
1. place a doc to scan in the scanner. Close the lid and hit MENU, COPY document, START.
If that doesn't work you'll need to contact kodak. If it does then try this next:
2. Check for ADMINISTRATOR rights.
  1. RIGHT CLICK on the kodak icon and select Properties > Compatibility tab > Run this program as an administrator
  2. Select RUN AS ADMINISTRATOR
  3. click APPLY
  4. click OK
Then try scanning again. If it still doesn't work then-
Reload the driver:
  1. select Start > Run.
  2. Type %windir%, then click OK.
  3. Double-click twain_32.
  4. Right-click Kodak, then select Delete.
  5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to (cd drive: > printer > scanner.
    Double-click aioscannr.msi, then follow the instructions to remove it
  6. Then go to cd drive: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
  7. Open Home Center Software
  8. Select Scan Documents and Pictures.
  9. Scan a document
If it still doesn't work then you'll need to take it in for service.
Jun 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
How may I scan a document?
Overview: To scan a document you need a scanner and scanner software, this answer will cover
the steps necessary to scan and save a document.
  1. You must already either own or purchace a scanner (eg: this model)
  2. Connect the scanner via the provided USB cord. Consult the manual for this step as necessary.
  3. Use the provided scanner drivers (Consult your scanner manufacturer's website to obtain) and scanner utility to preview the document.
  4. Adjust the settings as necessary and preview your document, if satisfactory enter a name for your scan and save it.
Mar 07, 2011 | Computers & Internet
How do I use my x5495 to scan a resume and then to edit it with my Dell XP computer?
You'll need to scan the document with an OCR software package (Optical character recognition) that will recognize the letters themselves and transmit them to word processing application, such as Word for Windows. Most scanner packages come with some form of OCR utility, so check your installed software. You may already be set up!
Best of luck, William
Mar 03, 2011 | Lexmark Office Equipment & Supplies
Could any one tell me how to scan documents in extra length?
If the document is too large for the scanner, then scan different parts of the document in two or more scans. Then open a Word document and paste the scan parts into this Word document - adjust the images to create the whole page.
Dec 31, 2009 | Syscan TravelScan 2300 Scanner
Same problem Microsoft document scanner cannot see scanner
did you change o/s //some cases you need a different driver/check their home page(cannon)//oz
Aug 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error when scanning over 6 pages
I thing you exceeded the data limit so cut the last 5 pages and paste to one new document now scan the new document then cut the new document and paste it to original document. that's it.
Jun 09, 2009 | Fujitsu ScanSnap S510
Question about copying direct from scan to a Word document
Check if your Canon software creates a PDF image. A scanned image is a RASTER image, a series of dots, that 'appear' like text or drawing. You cannot use Ctrl-C or Ctrl-v. If the software creates a PDF file, you can cut & paste. Usr any good OCR (Optical Character recognition) software ad convert the raster image to editable text. Then you can cut & paste.
S. Moha, Chennai
Dec 02, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Scan and make changes to document later
You need to use OCR. Use the OmniPage Se application that shipped with your scanner.
Oct 07, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
2007 won't scan to Word using HP Officejet Pro L7580
unfortunately the following is from MS Word 2007 Help:
The From Scanner or Camera option for scanning documents and pictures is not available in Microsoft Office Word 2007. Instead, you can use your scanner to scan the document, and then you can save the file to your computer.
After you scan the document, you can use Microsoft Office Document Imaging to create a version of the document that you can edit.
Important The first step is to install Microsoft Office Document Imaging, which is not installed by default.
Sorry.
Sep 26, 2008 | Microsoft Office Professional 2007 Full...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
777 people viewed this question
Clive
Clive
old marine
old marine
Ekse
