Sony FD Trinitron WEGA KV-30HS420 30" TV Logo
Anonymous Posted on Apr 16, 2012
I get error code 3 from my sony wega kv-32fq86e TV
When I turn on the TV it sounds like starting but the after a second it shuts down again and the Pover lamp is flashing 3 times over and over again
  • Anonymous Apr 28, 2012
    OK, thank You very much. However I have some difficulties locating the components.
    On myTV-set, they all seems to have the letter and a 4 digit number Like Rxxxx og Cxxxx. Are they located on the main power supply board?
    Can You maybe help me with the value/type of the components that You are mentioning?
    Thanks in advance for your help.
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Apr 17, 2012
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987309
Points
237762
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672
Testimonial: "OK, thank you very much for Your help. I will take a look at it or else send it for repair."
  • 1 more comment
  • The Knight
    The Knight Apr 29, 2012
    The four digit number you see is the part number. Here T603 stands for Transistor 603. R762 stands for Resistor 762. You must have sound knoledge in electronics to follow the circuit. This is the main power supply regulator section, where AC mains voltage comes in first, and the gets regulated, and goes to various circuit parts of the TV. This is the most fatal circuit secton for an unexpereinced to work with, because, all parts at the primary side of the main rectifier section will have high negative potential [floating negative], and is very dangerous to touch. B+ ver voltage, means, the regulatoed voltage from the power supply out to various sections circuits, are higher than normal. The power supply regulator section should be checked for fault, ans must set it right at first. A very skilled job indeed.
    In my opinion, it will be best cor you to contact any expereinced service technician to get this set repaired, rather than making things more worse.
  • The Knight
    If you thisnk you are handy, and have confidence that you can do this work, downlaod the service book form internet and follow it.
  • The Knight
    If you want its repair book, send your email address to me. I'll send a copy of it to you by return mail.
5 Related Answers
Anonymous
  • Posted on Jul 09, 2008
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
1. Place set on flat solid surface (garage floor or driveway).
2. Bang into it with SUV 3 or 4 times.
3. If set fails to respond, crush against garage wall or drive over it
Anonymous
  • 563 Answers
  • Posted on Jul 11, 2009
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
mortworker
  • Posted on Jun 15, 2008
SOURCE: Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
My Sony KV36HS500 Trinitron is doing the same thing. Last night the next street over was hit by lightning. The "7" blink pattern was happening, so like the manual stated, unplug it for 4 hours. Which I did. The t.v. is back up and running fine. It's a nice t.v., better than the plasma I paid over a grand for, that's already shot. It's a good t.v. and good that Sony put in the stand by protection to prevent the t.v. from dying an unnecessary young death. Patience, don't rush it, unplug the t.v. and leave it sit. Also, don't use a power strip, that was my mistake, and unplug your t.v. if storms are in the area, I was too lazy to and now I had to deal with this, in 8 years, only twice did this happen. I'd buy another one tomorrow if they still made them.
Anonymous
  • 563 Answers
  • Posted on Jul 12, 2009
SOURCE: My Sony TV: FD Trinitron
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
Please post a comment if you need additional assistance so that I can help you further.
Chi Chu
  • 8457 Answers
  • Posted on Aug 23, 2009
SOURCE: sony wega KV-36FS13 standby light blinking 5
Ur power ic inverter board is dead.
U need a new one.
2answers
I have a Sony Wega KV-34HS420 TV that takes several tries to turn on. When I push the power button or remote power on I hear the normal click and the sound comes on for 3-5 seconds but then I hear a second...
Since the set appears to "recover", it suggests either a poor solder connection or bad cap somewhere in the power supply. The 7 blinks indicate the problem circuit is in the horizontal area. Check the regulator (STRxxxx) IC in the power supply. If you do not have experience working with TVs, please refer this repair to a shop. The regulator IC costs around $25.
Dan
2answers
Same problem - tv shuts down
Sounds like you've got a problem alright, It's definitely heat related. I would suggest unplugging it and having it looked at by a professional.
I am an electronics tech and can tell you that you should not try to fix it yourself. There are voltages inside that tv that can literally throw you across a room and kill you instantly,
Also, I advise leaving it unplugged until it is looked at, A short can cause a fire.
Sony FD Trinitron WEGA Tv KV32FQ86E two flashing led
The high voltage power supply is going bad on both units.. Pretty soon, it won't power up at all. For a fact.
Don't try to replace the power supplies, TV's are too cheap.
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
15helpful
2answers
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
2helpful
Tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
2helpful
Sony kv-32fq86e 16 blinks
If red led blinks continously , please check horizontal o/p or EHT screen control reduce and check for power on
sam
2answers
No Power on Sony TV Model KV 36FS120
Hiii....
The sympthon 9 blinks :
Check at G board : D6301 D6116 ( replace with new one !!!! ).Voltage around +/- 12 -13 v .
Thank's
[Vrya]
e-mail : [email protected]
Sony Trinitron KV-28WS3U Dies
B+ over current protection (OCP), unit goes to the standby mode. Could be a short in the power supply of any of the circuits.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
