3.0 engine
SOURCE: troy bilt tuffy with 3.0 tecumseh engine.
Contact Information:
http://www.tecumsehpower.com
900 North Street
Grafton, Wisconsin
53024 USA
Phone: 262-377-2700
SOURCE: Troy-Bilt Tuffy 2006 model keeps having weird engine problems
Make sure you haven't used ethanol-blended gas in a briggs small engine. It will destroy the plastic internal carb pieces, thereby causing your carb to leak gas into the crankcase and flooding out the engine. If you check your gas it will be really thinned out, gassy smelling and black. It will also be overfilled.
SOURCE: does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
SOURCE: need a manual
here is the Tuffy webpage at the troybuilt.com... directly under the photo of the tiller is a gray "download manual" link...
best wishes,
k
SOURCE: Can't start my Troy Built Tuffy tiller
First pull your spark plug out reconnect to the plug wire and ground tot he engine body
Pull the starter cord and see if you have a good clean spark that goes to the electrode and not to the side of the spark plug.
If no spark check your off/on switch
