It is on silent mode and I can't get it off
Since you declined to specify the model of your Uniden DECT 6.0 phone, I can only suggest that you select it from the list beginning here to download a copy of the manual.
SOURCE: how do you turn off silent mode on Uniden DECT 6.0
In standby mode pressing and holding # brings up the "Silent Mode" special feature .. unfortunately the only options are to set the time for the device to be in silent mode and no way to turn if off. The solution is supposedly to press the # key again and hold it down, but this does not work either. The only way I can manually return to not be in "Silent Mode" is to reset the base unit!!
SOURCE: how to take silent mode
To turn off silent mode, press the "#" and hold down until it changes. :)
SOURCE: I have a Uniden 6.0 DECT cordless phone. Misplaced the manual.
Since you dont list which specifc model you have, I cannot list the specific manual. But here is a link to Uniden's list of manuals, you should be able to find yours here. http://www.uniden.com/index/manuals_results.cfm?cat+1
SOURCE: UNIDEN DECT 6.0
DECT 6.0 is not a model number, it's the generic name for the cordless phone technology in use. So I can't give you a more specific link than this one, which takes you to Uniden's download page for manuals. Pick your model from the list, and the manual will explain the steps you'll need to follow. Your phone's model number is on a sticker normally found on the rear or bottom of the base unit.
Testimonial: "thank you very mucy "
SOURCE: Need Owner's Manual for Uniden Cordless Phone Model 2180-3
Here is the link. to a pdf version of the phone manual.
