My machine is leaving black marks, seems to be grease on my white material? I have cleaned and oiled and it is still happening.
"16. When dismantling the rotary hook (left turn screw ) or replacing it, the boring of the hook, its pinion as well as the 2 thread release cams must be lubricated with Supergllss oil (Renotac) 458'180.
17. Generally, if not mentioned otherwise, the following hints may be of help for lubricating
- Use Tectyl oil 458'170 where only metallic parts are implemented, i.e. bushings.
- Use Supergllss (Renotac) 458'180 where metallic parts are working together with parts of synthetic material.
- Use Supergliss or Silicon oil 803'531 where only synthetic parts are in friction with each other.
- Do not use Molykote DX grease 458'460 (white) on parts made of Lexan like shells or handles.
- In these places, you may use Silicon grease 802'940 as well as on slides, pivots and similar friction points. "
However, I wouldn't dismantle the rotary hook unless you have experience with sewing machine repairs, being computerised these machines are quite different to a standard mechanical machine.
