Ink jet and cartridge tray do not move when turn printer on or off. (I believe that one or more cartridges ware low on ink).
SOURCE: Canon BJC 6000 Beeps and Power Light Flashes Orange
The 6 beeps along with the orange light stands for "Re-install BJ cartridge or replace it". You might have already fixed the problem by replacing the cartridge, and you're still stuck with the error indication. Waste Error Reset 1: Power off printer 2: Hold Resume button then press and hold POWER, the beeper will sound once. 3: Hold POWER and release RESUME 4: Press RESUME twice 5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange. 6: Press Power to set data If it still doesn't go away, try cleaning the contacts the cartridge makes with the printhead. Dip the carts contacts(dipping only the contact area) in shallow hot water for a minute, then wipe dry with a cloth that doesn't shed fiber. Also clean the contacts on the printhead using a damp cloth, maybe also some alcohol. If it still doesn't go away you have to think of replacing the printhead, or chucking it. Good luck
SOURCE: Printer Problem
This did NOT solved my flashing led (15 times) also magneta led is off and when i re-install the cartridge its just a second on, and the flashing led is back 15x !! it driving me nuts..
How do you got this solved?
1) With the printer power turned off, while pressing
the Resume/Cancel button, press and hold the Power
button. (DO NOT release the buttons. The Power LED
lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the
Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and
Power
LEDs light alternately, Alarm in orange and Power
in
green, starting with Alarm LED.)
4) When the Power LED lights in green, press the
Resume/Cancel button the specified number of
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
Resume/Cancel button the specified number of time(s)
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
SOURCE: My canon ip1880 printer orange light flashing 7 times.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
SOURCE: Left hand light flashing orange and printer wont
Check the following:
Make sure you have removed the seal on each cartridge.
Turn of Printer, open all shutters, front and back and close them firmly, firmly.
Make sure there is no paper jam.
Usually these are the immediate causes of this kind of scenario.
Then try to print again.
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
