SOURCE: on my canon FS200 for the imagemixer i enter the
I had a hard time finding it too. Finally figured out that its the 12 digit number written:
XXXX
XXXX
XXXX
on the tag that stuck to the battery door
SOURCE: where is the serial number on my camcorder FS200
It's listed on the Canon warranty card that came with it. Hope that helps.
SOURCE: Where do I find my Canon FS200's serial number?
Check the bottom of the camera or behind the battery. Also, The SD software that comes with the recorder has a little glitch (ONLY with the colored units; the blue and red) when entering the serial number to register the software it doesn't recognize the serial number from the unit. You actually have to change the first 3 numbers from 822 to 808 to get the serial number to accept. I found this from an earlier review on this site.
SOURCE: Where is the serial number on the CAMCORDER FS200
Problem solved by local canon agents. Thanks. The serial no. was on the packing box preceded by a <21>. no mention was made that it was a serial no.
Thanks again
SOURCE: wHERE IS the SERIAL NUMBER
You can look for the serial number either under the camera or behind the battery.
These are the normal places to find the serial number.
Let me know if this solved your problem!
Regards
