SOURCE: I have a Scotts Accugreen 3000 Drop Spreader. How
I found drop-rate tables at http://www.vigoro.com/ProductCategories/WeedInsectControl/SummerFertilizer/ProductDetails/Spreader+Settings.htm and http://www.bayeradvanced.com/media/productlabel/502840A_label.pdf. I don't know how accurate they are, but they are consistent with one another so I'm using them :)
SOURCE: IS there a place that lists spreader settings for
If the product you are planning on applying has a spreader setting for a Scotts AccuGreen, or specifically for the AccuGreen 3000; you can use that recommendation in your Turf Builder Classic Drop Spreader. If they do not have a suggested spreader setting for the Accugreen, or Accugreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
SOURCE: What would be the setting to cover 4 pounds of
Unfortunately, because granular products come in many different particle s and densities, there is no way to determine a universal pounds per thousand spreader setting. The only solution would be to do a 50 foot by 20 foot test. The 50 by 20 rule will allow you to determine an appropriate pounds per thousand rate for any product in anyspreader, but there is some work that will need to be done. *Weigh out and Place enough material in the hopper to cover 1,000 sq. ft. (Inyour case 4 pounds) *Place the spreader setting on a low setting about 1/4 of the way open. * Apply the 4 pounds of material over a 50 x 20 ft. area (This is 1,000 sq. ft.). *If material is left over, you are underapplying, and will need to increase the setting accordingly; before applying to the remainder of the lawn *If you come up short, you are over applying and you will need to decrease the setting; before applying to the remainder of the lawn
SOURCE: I have an older scotts drop spreader, called a
The best way is to just place a small amount... like 5 lb in the hopper...start with it barely open and see how far you get,,, then compute from there what you need...
The settings they give you are guesamates at best and are often set to place too much... why not??? they are selling you a product!!
heatman101
