SOURCE: Printer MP287 Canon pixma inkjet
Printer MP287 Canon pixma inkjet Keeps displaying the error 5200
What can i do ?plz help me
Linda
[email protected]
SOURCE: canon PIXMA MP287 driver
just visit this link: http://www.canon.co.in/p/EN/155-All-In-One/368-Inkjet/1661-PIXMA-MP287/
hope it helps thanks!
SOURCE: canon pixma mp220
I had the same problem, and this is the fix.
1. Go to Canon's website and find the "Drivers and Downloads" section. From there, you will need to specify the subcategories of your hardware, and then your specific model (for example: Hybrid (i.e.-Printer & Scanner), Inkjet, MP470 Series)
2. When you find the proper page for your model printer, select your operating system from the drop down list.
3. Scroll down the page. You will see all versions of the drivers and programs to download. Download the latest version of the driver. You should also download the "My Printer" program. This is useful for troubleshooting and maintenance.
4. Keep scrolling until you find the "MP Navigator" program. This is a very important program, and is necessary for the scanner to operate properly. Download this program.
5. One MP Navigator is downloaded, verify that the scanner will use this program when it operates. To do this, go to the Start menu, click on Control Panel, click on Scanners and Cameras, click the printer that you will be using, then click properties. Click the tab at the top that says "Events." You will then see a drop down menu with the options Save to PC, Save as PDF, etc. Verify for each option that your computer is either opening the MP Navigator program, or that the computer will prompt you on which program to open.
This should get your scanner working. Hope this helps!
SOURCE: canon MP600 won't scan
i would say maybe first step os to unistall all canon mp600r software
includin scanning programs and reinstall them and see if it then works.
this might cure your fault but make sure you do it from the setupdisc
not the canon website.
Hope this helps
SOURCE: Canon - Pixma MP150 printer/scanner won't scan in color.
hi,
u've to install all third party drivers related ur printer that u've got on time of purches.
