2004 Lexus ES 330 Logo
Posted on Apr 16, 2012
When I start the car there's a loud sqeeking noise that goes away after 1 minute 2003 es 330
Hamish Construction
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Nov 17, 2014
Hamish Construction
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
1249
Points
14
If it was mine, I would buy some "fan belt dressing spray" and spray my fan belts or have them adjusted. first spray them once, if sound stops a few days, have the tension adjusted. if spray does not work the first time, this is not the problem.
1 Related Answer
Randy Ohler
  • 14585 Answers
  • Posted on Jan 22, 2011
SOURCE: I have replaced the bulbs but why does my 2003 es
You could have a loose connection at the power pack, Or the power pack is dieing.
Hello, \r\nI have a 2003 dodge neon SE. I hear a loud roaring noice and vibration from the front end, the noise is really loud (like a truck) when I start it. When Car in drive the noice is loud but when I...
Hey Shona... Please take your car to a qualified professional... this could be something very serious related to safety.. do not take a chance.. let them diagnose your problem..please...
2helpful
2answers
2003 Prius: High pitched noise, ABS & BRAKE Lights on
Check your brake pads first,as they have a wear warning clip on them.so if you hear a loud screaming noise.Then its quite possible they have worn causing ur warning lights to come on.And i would get anouther quote as that is quite dear for a pump replacement.If it is the pump.good luck pippall!!
2003 jeep cherokee 2.8 CRD engine sqeeking noise
It could be that you got some water on your serpentine belt and that will cause it to squeak. Try buying a can of "belt dressing" from an auto store and spray it all over your belt and see if that will stop it. It's a cheap and easy thing to try before replacing expensive parts. Hope this works for you, let me know how it goes. Goodluck!
Loud ticking noise on startup
I would have you oil pressure checked. The oil pump or bearings could be going out. The lifter noise on this car usually will go away faster then 5 minutes. I think the noise is lasting a little to long.
1helpful
Right front makes a noise when turning right when the car is cold
sounds like you have a wheel bearing assembly going bad
2answers
Noisey front end
Change the tire. Your tires might be worping from the inside. I had the same problem. It might need an aligment too.
Top Lexus Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Are you a Lexus Expert? Answer questions, earn points and help others
