We installed a saniflo plus macerator for a full bathroom in March. Since just yesterday, whenever someone takes a shower, the rubber elbow off of the macerator actually comes off and water starts spraying out. We've re-clamped this, but it happened again today. Has anyone else had this problem? Any solutions?
SOURCE: pumping stopped
Well it sound likes you have 2 problems. 1st is the float switch is set to high,and pump wont come on till it raises higher then tray. 2nd. sounds like empeller came lose from shaft. I hope this help. :)
SOURCE: My macerator turns off and stops working for 10 - 15 minutes
the macerator is over heating.check the maintenance opening and clean it ,but you may need a more powerful macerator,some are made only for flushing systems (as in toilets) a pro-longed use may be making it overheat.. good luck
SOURCE: The water from the loo and shower is rising & not going down
The outlet is blocked , get an engineer in to fix it pronto
SOURCE: Saniflo Macerator Noise
If it's a one shot cleaning and not an ongong additive, bleach can be used to dissolve the tissue.
Charlie
Testimonial: "i havent tried it but its very helpful. Thanks."
I've got exactly the same problem. It's nothing to do with the suggestions below.
