So i use err, 2 modems, 1 acting as a route to the modem which is the D-LINK DSL 2640B, and the other one for the modem, to connect to the internet, they are both synchronized. The problem is, when i enable the wireless, after a few minutes it got turned off automatically , i don't know why, i tried rebooting after enabling it, but it still won't work, any solutions anyone? PS:192.168.1.2 is for the route, and 192.168.1.1 is for the modem.
SOURCE: how to connect ADSL 2 modem to Wireless Router
just change the ip address in the router and give the proper settings in the router
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
SOURCE: d-link DGL-4500 is not accessing my dsl modem
make sure the dsl modem is in bridge mode. you do this by connecting directly to the modem then accessing modem configuration page. after doing this connect the way everything was before. now go to router admin page, then setup tab at the top, then choose internet, manual setup. in the place where its says my internet connection is select PPPoE. then put in your dsl username, password and etc. save settings. this should fix the problem
SOURCE: Ethernet connection of DI-524 does not work
You have to make the Ip changes on the laptop not on the modem.
You said you have internet acces on one computer. Then use that computer to find out the exact IP address used by the modem.
On the laptop use the exact same numbers, (IP, Sub mask, Gateway, Primary DNS)
and chek if it works.
If you want to have both computers on the Internet, simply change the last number on the IP address ONLY.
Please don't forget to rate this answer if it helps
SOURCE: I have just set up a D-Link DSL-2640R Wireless-G
Check that your router is set to a channel that does not have a lot of traffic on it. If you are in an area where there are a lot of wireless networks, this can be very important for proper operation. The other possibility I can think of is that the antenna is faulty or there is some other interference in your building. You might also check that your router does not have a low power wireless transmit mode, not many do, but if it does, it's always possible that it's turned on.
Testimonial: "Other wireless net works are in the area so this sounds like the cause, my problem now is I don't know how to change the channel on the router. "
