Need to see where plugs belong
Front panel connector is 4 pins + one empty on top row and 5 pins and one not connected on bottom row.
From the left on top row, 1st 2 are power led, next 2 are power switch, next has no pin
From the left bottom row 1st 2 are hdd led, next 2 are reset (rst) led, last ob right has no connection.
Note the power led and hdd led connectors produce a light when pc is on, if the light does not come on, power off the pc, turn the cables through 180 degrees and turn back on and a light will show
Have a look on the techguys tab at pcworld.co.uk, you will be able to download the maual from there
