My Canon MV650i MiniDV camcorder died after 5 years of sparing use. The authorized Canon service center cannot get the spare part (DC-DC board).
But there is a priceless tape stuck in the machine! I have (carefully) partly disassembled the camcorder. Is there a way to manually eject the tape?
Hannes
I just solved my own problem by disassembling the camcorder until I had access to the little motor which operates the eject mechanism. It sits on the corner of the mechanics subassembly, close to the cassette. By applying about 3.5 Volts DC from a regulated power supply to the two motor contacts, it started to operate (test which direction it needs to go by trying both polarities) and lifted the cassette out of the play position and ejected it. Only since the tape was still wound around the drum, I had to use a thin tool to turn the cassette hub in order to tighten the tape a bit. Then the protective cover of the cassette closed and I could slide the cassette out of the slot by hand. Bingo!
I have a JVCGR-D340EK camcorder. I bought a Dazzle to transfer my recordings onto a dvd but cannot understand the instructions. Do you have any idea how to do this (in layman's terms) please?
SOURCE: Camcorder is dead, need to get the tape out!
Problem : I cannot eject the tape from my digital video (DV) camcorder.
Cause :No power source or depleted battery pack
Solutions
Did this article answer your question?
SOURCE: Canon MVX200i Mini DV Digital Camcorder: Remove the cassette
I got the same problem, does nobody has a solution. Please help!!
Eduard Mendlik
SOURCE: eject mechanism not functioning
I too have same problem. The service people say that the whole deck has to be replaced which I do not believe. I think the pinch rollers have to be leaned and brake system to be adjusted/calibrated. The local mechanic would do that.
