Southern Telecom Emerson Bluetooth Headset Black Wireless Headset Logo
Posted on Apr 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My emerson 228 is flashing blue and red and I know it needs to be charged but when I plug it in it turns red for charging and then 2 seconds later the red light goes off and no charge I tried two different chargers still won't charge!!
Anonymous
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 174 Answers
  • Posted on Apr 17, 2012
Anonymous
Expert
Level 2:
New Friend:
Cheetah:
Answers
174
Questions
Helped
40889
Points
337
The charger dont work i hope you have garantie
1 Related Answer
Anonymous
  • Posted on Jan 12, 2009
SOURCE: bluetooth wont turnon new unit out of box
Pardon me if you have already tried this but with my em236c I had to hold the Answer/End button for about 15 sec before it flashed red/blue. The manual doesn't say how long to hold it. It took a couple of tries for me. Hope this helps.
My Wii intec induction charger model G5857 wont charge my Wii batteries.The charger worked 4 1 year.I don't know which is the problem.I don't want 2 spend more money on a new set of batteries/charger.
first are you now using li batteries or nicad batteries
small chargers are battery composition specific
secondly-- chargers for aa /aaa batteries are cheap so get a new charger for the batteries in use
Why have I got a red light on the bottom of my shaver when I am using it
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here: http://www.manualslib.com/manual/20281/Braun-5301.html#manual
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
capacity.
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
1helpful
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
8helpful
2answers
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
2helpful
I HAVE A NOKIA E71,BUT MY EMERSON8227A-BH08R NO CONNECT, NO FIND A BLUETOOTH
Emerson EM277.
Make sure unit is fully charged (no red indicator when plugged in).
Press and hold the power button until indicator rapidly flashes red/blue back and forth.
Search for device again. More detailed instructions here.
http://southerntelecom.com/emersonsupport/downloads/EM227.pdf
2helpful
Bluedio T9 Bluetooth won't charge
Well... I've got the n65, and this is the third time I've gone to charge it. Solid red, won't turn on no matter how long its been plugged in, can't find the manual, this fixya page is the best result online...so my solution is to stop by the local cell-phone accessory shop to buy something new.*
*Results may vary. :^s
Jan 13, 2010 • Cell Phones
1helpful
I Can`t switch my headset on, and it stops charging after 20 secs
Move the call control button up or down, the indicator light will flash blue if it's paired or blue and red. If it flashes blue and red you need to pair phone with the headset. the passkey is 0000.
3helpful
Bluetooth wont turnon new unit out of box
Top Southern Telecom Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Southern Telecom Radio Communication Expert? Answer questions, earn points and help others
