SOURCE: i need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
SOURCE: Roland Dp 2 Damper Pedal dont work
I'm 90% sure the pedal is shot ... It could be the switch ... Open the thing up (If your confident) and look to see if a wire has come loose ... If no wires are loose then try another working pedal with the keyboard.
If it still won't damp then there is a problem with your keyboard and I do not suggest opening up one of those ... I used to repair sockets and keys on those for a local boys school and there are full of things that can break if not opened properly,
My suggestion is getting someone in to repair the keyboard if its that ... If its the pedal then either get a new one if you don't want the old one repaired ... Or repair it yourself (pretty easy if its the wiring ... fiddly if its the switch but only attempt if your confident and have the proper tools).
SOURCE: My sustain pedal does not work on my Roland Juno-D keyboard.
Have you tried the pedal straight into the amp without going thru the Roland?
Does the sustain pedal turn on with the foot pedal or is it a separte stomp switch to turn it on?
SOURCE: Roland RD-700SX as MIDI keyboard
Theres a good article at recordingreview.com. If you join which is free you have access to a lot of great information. You can download Midiox to troubleshoot your midi connections etc. Make sure that your transmit channel on your keyboard matches up with the receive channel in your program. Hope this helps.
