Kitchen Appliances - Others Logo
A
Anonymous Posted on Apr 14, 2012
Waring wine opener wont pull out cork
Waring wine opener
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4923
Points
We learned that NONE of these electric wine openers like the new "plastic" corks. Take a needle nosed plyers and hold the cork tightly(as it sits inside the housing) and gently push the button to release the cork. it should work.
  • Anonymous Nov 27, 2012
Pieter Vleeshouwers
Level 3:
  • Sunbeam Master 2,029 Answers
  • Posted on Apr 21, 2016
Pieter Vleeshouwers
Sunbeam Master
Level 3:
Answers
2029
Questions
0
Helped
4112520
Points
7389
All so difficult cork problems botlles kagor or Moldavian dessert wines or corks that are bad when this kind of cork removers bring the right help . twist point for point Move your first long point in until the short point approaching the cork will then turn the springs between the cork and the bottle neck in turn twistend to handle at the neck of the bottle and turn the cork slowly, the cork almost always undamaged rotated out of the bottle, and if it is really a super hard bonded cork is ios for tightening just keep the bottle upside down when his two feathers stuck deep in
waring wine opener wont pull out cork - waring-wine-opener-wont-pull-out-cork-hozzjike5mcrqhs4pnq42myf-4-0.jpg
2 Related Answers
Anonymous
  • Posted on Sep 01, 2011
SOURCE: I have an Oster Electric
Use a screwdriver (or whatever) to push the inner ring at the opening as far inside the appliance as you can. It is a black piece with a spring action that has plastic molded ridges inside. The ridges on the inner edge of this will grasp the cork. Then, while you are holding the inner section in place as far inside as possible, push the button to operate the opener and the cork should come out as it normally should. I had half a cork stuck up there, and this just worked perfectly.
Anonymous
  • Posted on Jun 05, 2011
SOURCE: A cork is stuck in my Oster Electric Wine Bottle
We had the same problem, and we took the thing apart, unscrewed the cork from the corkscrew and put it back together. You have to make sure you line everything up properly inside, though. There are contact points that need to be lined up on the inside.
Oster electric wine opener wont pull out corks. Half of the cork, or part gets stuck up in the unit. Has always worked fine up until day before yesterday. Is is shot? Or cork puller not sharp anymore?
You need to replace the battery pack, pull it out and see what type of cells are used, then build a new battery pack, did this on my own opener and wow it really rocks, lots of power.
2answers
Cork stuck in sharper image wine opener
The black plastic ring is secured on the clear tube that you can see the corkscrew through with four little plastic snap tabs. I used a pair of channel locks to gently pull the ring off those tabs. Once you do that you have access to the inside of the clear tube and can reverse the corkscrew and get your broken cork out. Blow debris out and reassemble. Good as new! Even if you break one tab it should still hold, and if you break multiples use some super glue to hold it in place, that will be your last chance to fix it, but at least you've doubled the life of your toy. Good luck!
Aug 05, 2014 • Home
2answers
How can I replace a pig tail on a bottle opener
The following seems to work, but might be tough if you don't drink the wine first. http://www.youtube.com/watch?v=5Y82j3R7tXw
Jul 02, 2014 • Home
Won't pull cork out
Battery may be soft. N/G
If it goes in with No Problem and will not pull out
The cork is stuck in the wine opener when I was trying to release the cork after the wine was opened
I used a long tweezers -- about 1 ft long. I held the cork in place, then pressed the reversed button. It came right out.
Cork stuck in wine opener
amazing that noone has answered this question including the people at Waring - I have no idea how to do this
Weak battery
then the rechargeable battery is dead. take it to Batteries Plus to have them replace it
How to remove cover from waring pro wo50
A broken cork was stuck up inside my Waring Pro Wine Opener. Model WO50B. No amount of maneuvering could get it out. I removed the two small screws holding the silver part of the opener on. After that was off I could see two more screws and I removed those. The unit still would not come apart. I noticed that there were four oval shaped rubber plugs up on the black part of the unit. I pried the ovals out with a wooden skewer. That exposed the other four screws holding the long part of the unit together. Once I got those out, I gently pulled the two sides apart about an inch. I could have pulled it completely apart at that point (I think) but from there I was able to free the broken cork from the big internal cork screw. Everything screwed back together fine and the unit works again.
2helpful
Cork will not come out of opener
This is from Jen8926 in another forum and it worked for me (push up the inner sleeve an inch or more inside the main tube): Use a screwdriver (or whatever) to push the inner ring at the opening as far inside the appliance as you can. It is a black piece with a spring action that has plastic molded ridges inside. The ridges on the inner edge of this will grasp the cork. Then, while you are holding the inner section in place as far inside as possible, push the button to operate the opener and the cork should come out as it normally should. I had half a cork stuck up there, and this just worked perfectly.
2helpful
How do I open a bottle of wine without a wine opener?
You can push the cork into the bottle and extract it by using a cloth napkin inserted
into the bottle. It pinches against the cork and allows it to be pulled back out.
There may be a video on youtube about this.
Top Sunbeam Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
Thomas Perkins
Thomas Perkins
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
