I've been reading many posts about the issue I have been having with my Dell w3000 for years now (have to turn tv on and off many times to get picture to show up - green light and audio are not a problem and always work). It seems as if there have been many possible solutions - the two that sound most reliable are replacing the inverter (http://www.lcdparts.net/LCDTVInverterdetail.aspx?InverterOriginal=6632L-0048) or replacing/fixing the logic board (http://www.lcdrepair.us/w3000-logic.html). Both options cost around the same amount and although the TV might not be worth as much anymore, I am still committed to fixing it as I have no other issues with picture quality, etc.. Can someone with expertise help me figure out which part to by? Thanks so much in advance!
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
SOURCE: dell w3000
Just fixed the second one of these for someone--was sound and at first loss of picture--then sound only---remove cover, remove metal shield over power and digital/signal board====take close look at both plugs from panel to digital board(top towards left) both units I have fixed the left plug and SOCKET were out of the board---detached---other plug looks ok---resolder left plug with very fine solder tip-----both sets had same trouble! good lead free solder?
SOURCE: Dell W3000lcd tv
HD
Ready does not mean that it is HD compatible without the addition
of an optional part.
The title only implies that it can be adapted to HD reception.
If you did not purchase it with the set, check your user guide to see what you
need to make it whole.
You may have to seek this add-on on eBay since it is not guaranteed that Dell will still offer it, or you can buy the convertor (with a $40 coupon) that many sets need.
You can order (backorder from what I read) the coupons here:
Convertor Coupons
After surveying many of the set-top convertors, I bought Zinwell ZAT-970 units for two older sets not currently in use but will now serve as backups when our sexy flat panels die like so many.
SOURCE: my dell w3000 tv wont power on
There are likely bad capacitors on the power board. You will need to replace 4 capacitors, labeled c101, c304, c305 and c404. I used 3 50v 33uf and 1 50v 47uf capacitors. The originals are 35v 33uf and 35v 47uf. Replacing these should fix most power board issues.
SOURCE: i HAVE A DELL W3000 30 IN. TV. I HAVE SOUND BUT NO
This sound like a lamp issue when this type of thing happens there is always a lamp problem change your lamps that will be a 95% that will fix your issue
Testimonial: "HEY THANK SO MUCH. BUT I HAVE ANOTHER QUESTION. HOW DO I CHANGE THE LAMPS?"
Same problem
