Check the micro switch that is attached to the tape run out arm. If open the reel motors will not operate.
The Capstan motor is just for the play speed regulation so it has nothing to do with the reel motors. You can have an open safety microswitch or maybe a bad relay. It is really hard to say without looking at the unit but I am sure it is repairable. Is the right dummy plug put in the back? This can stop all transport functions if it is out.
SOURCE: TEAC 2300S
http://www.angelfire.com/electronic2/vintagetx/manuals2.html
found manuals for low cost here...
SOURCE: TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it [email protected]
SOURCE: Teac X1000R Reel to reel
Hi there. It will need a new pinch roller, and has a bias oscillator. problem. From memory, they use a module for the oscillator, and the pinch rollers are easy to get. Sorting out the bias may be the problematic part, and you will need to recalibrate the bias traps and controls if you want max performance from the unit once repaired. I would go about checking things like intermittent tape bias switch, and try wriggling the record play switch( internally) and see if you can get erase and rec back. Noisy intermittent switches can caused the symptoms you have.
If you are able to, I would be seeking a refund. If not, then repairs are feasible. Let me know where you are and I can help you find a repair guy. Cheers
regards
robotek
SOURCE: RS-TR272 dual deck and capstans seem to be locked
DO NOT spray anything into this unit. The problem is a slipping belt and is a simple fix for any audio shop. While possible, it is rare for a motor to fail. There is a small belt that drives the take up side along with a felt clutch assembly that can slip. If this is the case, the unit will realize that the take-up reel is not turning and shutdown the unit. Please have this serviced. The belts will run around $6-$10 total.
Dan
SOURCE: I have TEAC A 4010. Motors are running, belts are
Ensure the rubber pinch roller presses the tape against the capstan drive shaft....ensure the capstan drive motor is turning..and the belt to the flywheel is snug, and not slipping. the tape transport engage relay might be stuck...a relay maybe corroded ...may need cleaning. Without seeing it cant say clearly what may be the problem. also ensure the tape tension/shut-off arm is under tension by tape that is correctly installed.
