The machine is 3 years old. I tried tightening the grind one notch. BUt coffee is still to weak at the same settings as used to be great. Also pellets after grind are now sodden andd wet not dry as previously.
SOURCE: my delonghi esam5500 coffee bean grinder part is
In our case we were lucky. Grinder was blocked by the beans. This is what I have done with our Delonghi 5400. It looked fiddly but was quite simple really. I started from the back panel. Once back panel was removed I had access to 4 corner screws that remove both side panels. Now that give me access to 4 corner screws that hold top of the machine. I l also had to unscrew 5 screws that hold coffee container in place. 4 are visible once the coffee beans container is open, but the 5th is hidden in the middle of adjustment arm with a black cap on top.(adjusting how fine you grind). I used small sharp screwdriver to lift the cap. Once all are out I removed the top of the machine and then the funnely coffee container too. That exposed grinder assembly. Top of the grinder is actually loosely sitting in the lower part of grinder. Twisting it counter clock should release it I Think. Our was not budging, and I had to completely remove the grinder and detach motor but that is quite obvious too, and probably not needed. I just wasn't sure what I was doing. Our machine was out of warranty so... Would be nice if we had some schematics.
SOURCE: delonghi coffee machine service providers in india
please contact Mr. Prashant Suthar, India, www.debrewerz.com
SOURCE: DeLonghi Perfecta ESAM5500 when trying to make a
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
