the problem of it is compatibility here's the step1. CompatibilityThe PS3 supports only one headset at a time. Multiple players on the same console will have to share.
Bluetooth:
USB:
USB (wired) Headsets can also be used with the PS3.
Not Compatible with Bluetooth Stereo Headphones:
2. Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
In Game XMB:
For more help you can try these links:
3. Troubleshooting
General:
If you are having trouble with a headset after it is paired with the PS3, there are a few things to check first:
In ur options menu of ur ps3 there should b an "assign new controller or bluetooth device" or something of that nature. If u can't figure it out lemme know and i'll see if i can find u step by step instructions.
Make sure your Bluetooth headset is fully charged before you
begin.
Check your headset instructions for entering "pairing mode".
Activate your headsets' "pairing mode" so it can be recognized by the PS3.
On the Cross Media Bar (or XMB) of the PS3 go to the "Settings"
tab, then down into "Accessory Settings", then down into "Manage Bluetooth
Devices".
With your headset in pairing mode, follow the onscreen
instructions and let the PS3 scan for your headset. When your headset is found,
follow the prompts and enter a pass key (if necessary- the default is usually
0000 for all brands). The pairing should now be complete.
headset).
SOURCE: ps3 bluetooth headset
You need to "pair" the headset to the PS3. Follow the instructions for your headset (usually holding down the power button until you get a SOLID blue light) then go to Settings>Accesory Settings>Register BlueTooth Device>Scan. When you're done, you need to set your input device to your Headset model #, which should now appear.
SOURCE: connecting bluetooth headset to ps3
You have to do 2 things in order to use a bluetooth headset on your ps3. First you have to pair it with the ps3. To do this you go to your setting and register the bluetooth device. Make sure your bluetooth device is in pairing mode when you do this. On most headsets you can simply hold down the button until the light comes on a solid color. once it is in pairing mode you will have to scan for new devices. Once this is done you should see the headset on the list. Choose it and enter your pairing code. If you have not set one it will most likely be 0000. Once it is it paired you will have to change your audio output and input. Go to audio device settings and change the input and output device to your headset name. Enjoy!
my original headset will pair with my ps3 and everything works, i've followed guides on how to pair it correctly and stuff, and when i'm in game for killzone2 it says i'm speaking but no one can hear me at all, and its a really dissapointing factor. cause i'd like to play killzone2 and be ABLE to talk to people. I can't take it back because i bought it in the states and i go there once a year, my ps3 is new too, i got it for christmas. PLEASE HELP ME IF YOU KNOW HOW! Thanks.
