Brother MFC 210C All-In-One InkJet Printer Logo
Posted on Nov 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do not know which port to connect telephone line
Line or ext?
Anonymous
Level 1:
  • Contributor 37 Answers
  • Posted on Nov 13, 2008
Anonymous
Contributor
Level 1:
Answers
37
Questions
0
Helped
6914
Points
77
Connect the telephone line to line port. ext port can be used for telephone answering device or phone extension.
harsha gayan
Level 2:
Sergeant:
Champion:
  • Expert 246 Answers
harsha gayan
Expert
Level 2:
Sergeant:
Champion:
Answers
246
Questions
0
Helped
65853
Points
598
There is only one line to connect to telephone. it same to the telephone connection line.
Which port does the phone line plug in for fax capability
There are usually two telephone jacks on the rear - one is marked LINE and the other is PHONE or EXT. The phone line from the wall should go into the jack marked LINE. If you want to attach a handset as well, or pass-thru for regular calls, hook the phone to the PHONE or EXT jack.
2answers
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
2answers
I cant send a fax or reseave one
Sir/Madam
Solution one: Check the fax connections Use the following steps to check the physical connections, and then use the HP Fax Test Service.
Step one: Check the physical connections
  1. Disconnect the telephone cord from the HP fax product, and then examine the connector on the end of the cord. Make sure that the cord has only two wires. Figure 1: Two-wire telephone cord
  1. Four-wire telephone cordGraphic: Four-wire telephone cordIf the cord has four wires, replace it with a two-wire phone cord.
    If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
  2. Connect one end of the telephone cord to the telephone jack, and then connect the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
    Figure 3: Fax only
  1. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  2. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephon
  3. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  4. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephone
1 - Telephone jack 2 - Two-wire telephone cord to 1-Line
3 - Telephone
If other devices need to use the same telephone jack, make sure that they are connected to the 2-Ext port on the back of the HP fax product.
Figure 5: Fax with answering machine and telephone
  1. 1 - Telephone jack2 - Telephone cord from 2-Ext
    3 - Optional telephone cord to telephone
    4 - Optional telephone
    5 - Answering machine
    6 - Two-wire telephone cord to 1-Line
  2. Pick up the telephone receiver and listen for a dial tone. Make sure that you can dial out using the telephone keypad.
    If there is a dial tone and you can dial out using the telephone, the HP fax product is connected correctly to a working telephone cord and telephone jack. If there is no dial tone, check the configuration again and make sure that it is set up correctly.If You Still Having Hp Printer Problem Then Visit Official HP Printer Website On Below Link URL http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c02263145
Or
If You Still need HP Printer Online Help Then Follow Us On:
HP Printer Support
On the Fax part of the printer do I hook up a telephone line to line in port and Ext out phone port or just line in port to make the Fax work
You would connect the phone line to the LINE connection on the Printer/Fax.
The EXT OUT port would be where you would connect a telephone that uses the same line - for example on a desk nearby, etc.
Does the USB cable go into the LINE or the EXT connector for the X125
There is only one connector to hook the USB cable to on the back of the printer. You are probably confused with the telephone line connections. The telephone line from your telephone wall connector normally connects to the LINE in connector. A telephone line out to an extension or answering machine would be connected to the EXT connector.
See the quick set-up guide for how to set up your printer and make the telephone and USB connections.
1helpful
No dial tone on phone connected to ext port on epson dx9400f
Buy a double adapter so both cords go to the LINE port. Set your answering machine to 6 or 7 rings so the fax picks up first. Your fax machine will know the difference between voice and fax calls,
2helpful
Can't get the fax to work. It WAS working before.....
follow this simple steps:
1 .Connect the phone cable that came with the printer to the back of your modem to the port that says tele 1.
2 . connect the other end of the phone cable to the port on the printer that says "1-line"
3. connect the phone cable or cord that came with your telephone line to the back of the printer port that says "2-EXT" and the other end to the back of your telephone ..
This should solve the problem..best of luck
NO SETUP INSTRUCTIONS SUPPLIED WITH MACHINE. PLEASE SUPPLY
1. well its quite simple. all you to do is to connect the USB cable to the computer from the Printer (the printer also has a port for the USB)
2. then connect the main telephone line into the port labelled "LINE" behind the printer.
3. then you connect one end of the extra telephone cable supplied to the port labelled "EXT" behind the printer and the other end to the regular port on the telephone.
4. plug - in the power cable and put on the printer.
5. then you put the CD into the computer and run the set-up from the CD which is fairly easy.
6. after a few minutes you should have your printer running.
I have a hp officejet 4315v all in one printer,scanner,fax and copier and I dont know how to set it up as far as wear what fone lines go wear....please help
Connect phone line from wall to Line 1 in port - looking at machine from back, the port furthest to the right - then if you want to also have a telephone on the same line, run a second phone cable from the phone to the EXT port on the back of the machine - that 's the one immediately to the left of the Line 1 in port.
1helpful
Cannot receive faxes
Step one: Check the fax number
Make sure the fax number is correct; include any numbers that you have to dial to use the telephone, such as an area code, access codes for outside lines or long-distance services, and so on. If you have to dial a particular sequence of numbers to make a telephone call from that telephone line, you also have to dial that sequence of numbers to send a fax.
If the issue is resolved, you do not need to continue troubleshooting.
If the number is correct, continue to the next step.
Step two: Dial the number manually
Instead of using a speed dial setting or sending the fax from the computer, dial the number manually from the product control panel.
If the fax sends when you dial the number from the control panel, follow these steps to recreate the speed dial setting and insert pauses in the number.
On the product control panel, press the Setup button.
Press the Left Arrow button ( ) or Right Arrow button ( ) until Speed Dial Setup appears on the control panel display, and then press the OK button.
Press the Left Arrow button ( ) or Right Arrow button ( ) until Individual Speed Dial appears on the control panel display, and then press the OK button.
Press the Left Arrow button ( ) or Right Arrow button ( ) to select an unassigned speed dial entry, and then press the OK button.
Use the product keypad to enter any numbers that must be inserted before the fax number, such as an area code or access codes for outside lines or long-distance services, and then press the Redial/Pause button to insert a pause.
Enter the rest of the fax number, using the Redial/Pause button to insert pauses between the numbers, and then press the OK button.
Enter the name of the speed dial setting, and then press the OK button to save the speed dial setting.
Try to send the fax again.
If the issue is resolved , you do not need to continue troubleshooting.
If the issue is not resolved , continue to the next step.
Step three: Run a fax diagnostic test
Press the On button ( ) to turn on the product, and then make sure the product is correctly connected to the telephone jack.
Make sure that there is plain white paper in the input tray.
On the product control panel, press 6 , and then press 6 again.
This selects the Tools menu and then selects Run Fax Test .
The fax diagnostic test page prints.
Review the results of the test.
If the result of the fax diagnostic test is All Pass , skip to Step four: Reinitialize the fax.
If the result of the fax diagnostic test is a failure, a page prints that describes the issue and offers possible solutions. Follow the solutions on the printout.
If the solutions on the printout resolve the issue, you do not need to continue troubleshooting.
If the solutions on the printout do not resolve the issue, continue to the next step.
While the product is on, disconnect the power cord from the back of the product and from the electrical outlet.
Make sure that the telephone cord is fully inserted into the port labeled 1-Line on the back of the product.
Connect the power cord to the back of the product, and then connect the power cord to the electrical outlet.
When the product is in the ready state, try to send and receive a fax again.
Step five: Test the send/receive functions
Use the product keypad to send a fax. Watch the product control panel display and listen to the sounds the product makes.
If the product is working correctly, the following events occur.
When the product begins to dial, a dial tone is audible, followed by the sound of the product dialing. A Dialing message appears on the control panel display.
When the receiving fax answers the call, the product and the fax exchange tones. A Connecting message appears on the control panel display. During this phase, the product and the fax compare capabilities, exchange information about how to send the fax, and try to establish a reliable transmission speed.
After the connection is established, the product sends the pages of the document. Messages appear on the control panel display that indicate the status, such as Sending page 1 .
Review the results of the fax.
If the fax is transmitted successfully, continue to the next step.
If there is no audible dial tone or the receiving fax does not answer the call, try sending the fax to a different destination. If this second attempt also fails, continue to the next step.
If the receiving fax answers the call and begins beeping, but the Connecting message does not appear on the product control panel display, the product is not detecting the tones from the receiving fax. Continue to the next step.
Step six: Use an analog telephone service
HP Fax and All-in-One products are designed to work with analog telephone services and might experience some difficulties when they are connected to phone lines with digital services. Make sure the product is connected to an analog telephone service.
To obtain digital services information or support, contact the telephone service provider or system administrator.
Step seven: Check the phone cord and fax connections
Disconnect the telephone cord, and then examine the connector on the end of the cord. Make sure the cord only has two wires.
Figure 1: Telephone cord with two wires
Figure 2: Telephone cord with four wires
If the cord has four wires, replace it with a two-wire telephone cord.
Make sure the fax is connected directly to the telephone jack by a telephone cord. Connect the cord to the 1-Line port on the back of the product.
Figure 3: Fax only
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
If other devices need to use the same telephone jack, make sure they are connected to the 2-Ext port on the back of the product.
Connect a single-line telephone to 2-Ext , and then pick up the receiver and listen for a dial tone. Make sure you are able to dial out using the telephone keypad. If you hear a dial tone and are able to dial out using the phone, the product is properly connected to a working telephone cord and telephone jack.
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
5 - Telephone
Figure 5: Fax and PC or modem
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
5 - PC or modem
If you change any cable connections, try sending and receiving a fax again to make sure that the issue is resolved.
Step eight: Remove any other devices from the telephone line
If any other devices, such as a telephone, an answering machine, or a modem, are connected to the telephone line, remove each device.
NOTE: Remove each device even if it is in another room, connected to another telephone jack, or connected using a line splitter.
Connect the product to an analog telephone line by connecting one end of the two-wire telephone cord directly to the telephone jack and then connecting the other end of the telephone cable directly to the 1-Line port on the back of the product.
Try to send a fax again.
Step nine: Perform a partial reset of the product
A partial reset of the product returns all fax settings to the default values. It might be necessary to reset the language and country/region settings after the partial reset is complete.
Disconnect the power cord from the back of the product.
Wait 20 seconds, and then press and hold # and 3 on the product control panel.
Connect the power cord to the back of the product, and then release the buttons when the product turns on.
The product is reset to factory defaults.
Try to send and receive faxes again. If the problem still exists, continue to the next step.
Step ten: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Norman Weimar
Norman Weimar
k24674
