Sorry for the typing errors . The question is how do I connect the wires to battery receiver on archos 604 wifi, so that I can run archos 604 wifi without batteries, only on mains ( on the docking station dvr powered through mains.)Sorry for the typing errors . The question is how do I connect the wires to battery receiver on archos 604 wifi, so that I can run archos 604 wifi without batteries, only on mains ( on the docking station dvr powered through mains.)
You can't post conmments that contain an email address.
HI, bought the following off ebay and they worked just fine. I to thought that the socket on the right side was audio only. Can't get a picture via my DVR (may be a fault) however this item works great.
yes you can, however the battery must be inserted into the 604. Simply dock the 604, ensure the dvr is turned on and the 604 will automatically turn on and start charging.
it must be the battery..While charging is pilot lamp lightning ?
To verify,just plug the USB cable to see if device battery charging circuit is working..Device should work normally..
If it does,either your battery is dead or its charger needs to be changed.
Kazim
If you mean will the Gen 5 DVR Station Remote work with a Gen 4 DVR
Station, I believe it will for at least the basic player controls on
your 604 (except for the alpha keyoard entry because the Gen 4 players
did not have this feature enabled).
If you mean, will the Gen 5 DVR Station Remote control your Archos 604
directly (without a dvr dock), the answer is no, you must have a DVR
Station for the remote to work on any Archos player.
I had the problem that the record feature was not available in or out of the docking station and therefore i could not record. Archos connector on bottom of unit senses a change in the resistance of the device it's docked with and knows if it's the DVR station or not.
Turned out to be a hardware fault - i had to RMA both the Archos and the docking station (while in warranty) and Archos fixed it/them.
That may not help you much.
PS: I think i zapped my DVR station with static one day and that might have been the original cause.
i had this problem recently when charging on the DVR docking station, i switched it off, took the battery off, left it for a shirt time then pressed the reset, it took a few attempts but eventually it restarted
hi there, it should be easy, if your wanting to record off the tv/dvd or video you need to plug (lets say your using phono leads,the ends with red,white,yellow on them) into the output on the video (or what ever the device) the on the docking station plug them into input. then on the archos go to the videocorder n away you go. hope this has help`d
Are you sure the battery is charged? If so, try detach and retach the battery. Also try to attach to your computer via the usb cable and the 604 should turn on by itself, if nothing happens you need to send back to Archos for repair.
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
