I just bought this scooter chair (used) and 2 new batteries. i push the "i/o" button which i assume is for on. there is a picture of a key and inside it when i turn the scooter on a red light flashes. the scooter will do nothing except flash this light. is there a troubleshooting guide, or a typical set of problems for these scooters to look for?
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
SOURCE: scooter battery shows full charge but scooter does
Plamont unfortunately that flash code usually means a controller error. The controller is the brains of your scooter. Take the seat off and remove the rear shroud that covers the batteries and motor/gearbox assembly. Check all the wiring connectors for damage or loose connections. After checking the connectors turn the scooter on and see if you still get 8 flashes.
Did Medicare purchase the scooter? If so they will pay for most of the repair costs. You can contact your provider that sold you the scooter or a repair service Repair Xpress@ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
