SOURCE: outside caller hears themselves in an echo
Echo is usually caused by the transmit (speak) level on the unit being
set too high.
1. First, try lowering the volume of the telephone. If you
still hear an echo, adjust the volume of the headset itself.
2. The master
transmit controls of the headset are the ABCD switch settings on the
bottom of the base. A is the lowest and D is the highest setting.
3. You
can fine tune this setting with the plus (+) and minus (-) buttons on
the back of the charging base.
4. If this doesn't fix the echo, try moving
the configuration dial on the left side of the charging base. The
recommended setting for most phones is 1.
SOURCE: plantronics cs55 problem
Turn on the wireless headset as soon as the HL10 lifter picks up the headset. Remember to press the call answer switch. A steady green light should come on the base and the wireless headset should have a small green blinking light on, on its side.
* Make sure your hand receiver is off the hook when using the headset. Also check that you hear a dial tone on the handset/hand receiver before turning on the headset.
