When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
SOURCE: my notebook shuts down right after powering up
This is a protective measure. Your Processor fan is probably not spinning and cooling the unit. You can probably open the fan access on the bottom of the case (on most laptop). If you see the fan,clean it with cannned air and make sure that is spins freely. If it does not spin, you need to replace it.
If I could be of further assistance, let me know.
If not please rate this.
Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: false battery power alarm shut down
Ive had a look at the manufacturer web site but ther doesn't seem to be any driver for your model. You should be able to turn the battery warning alarm off in the management settings
SOURCE: My HP Compaq nx9030 wont turn on
try to remove your memory/ies. then plug it to ac power without battery, if it turns on try to unplug and put back the memory module (one by one if more than 1). plug and switch on if it works then put everything back if not, you ned to replacethe memory.
Hope this helps.
Please vote if it does.Thanks!
SOURCE: i have an acer aspire 3680 2682 that wont boot.
Try also taking out the hard drive and the dvd drive to make sure that they aren't shorting out the motherboard.
Also try another stick of memory besides the one that came with your laptop to be sure the memory isn't bad.
If after you do these steps you still can't get video then your motherboard is bad.
SOURCE: IBM thinkpad T30.The power button turned on then
There could e a problem with the battery. A fast check to determine whether you have a problem with the power
adapter, power cord or the laptop's battery is to turn off the laptop,
remove the battery, connect the power adapter, turn on the laptop &
see if it works.
If the laptop works directly from the power adapter
with the battery removed, then the power adapter is good. In this case
we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Testimonial: "Thank you for the advice, I did all of that, still wont boot up."
