Sony KV-36FS100 36" TV Logo
Anonymous Posted on Nov 14, 2006
Front controls mixed up & remote doesn't work
My kids were fighting over the channel and pushing buttons on the front panel and the remote simultaneously. The result was the TV can no longer be controlled by the remote and the front panel buttons are "mixed up". In other words the volume button now changes the channel, the on/off button sometimes works sometimes doesn't work. Sometimes to turn off the set I have to hold down several buttons. Also the display shows the channels changing continuosly (the numbers keep cycling down) but the TV remains on the current channel. Other than this problem the picture and sound work fine. The remote is OK because I have another Sony set that responds perfectly to this remote. I have tried to reset the TV using the reset feature on the remote, but again the remote doesn't have any effect on the TV. I have made sure I am pressing the TV button on the remote to make it work in TV mode. I unplugged the TV overnight and retried the next day with the same results.
Robert Johnson
Level 2:
Sergeant:
  • Expert 395 Answers
  • Posted on Jan 18, 2008
Robert Johnson
Expert
Level 2:
Sergeant:
Answers
395
Questions
0
Helped
151978
Points
887
The channel down button is stuck on, you need to replace this switch internaly to the set.
3answers
How do i set the chanel to 3 so that i can hook up cable with out a remote
Most sets it is impossible and will skip channel 3 and input. You will need to buy a cheap universal remote.
I have a 24 inch sanyo flat screen tv it is stuck on video and when I try to change the channel nothing happens I do not have the remote controller for this tv or any universal controller in general w
tried with unplugging and re plugging the tv doesn't work?. if not, tried to push any button like the channel up/down button and tv/video button at the front panel.
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
We lost remote control for our Orion 27" Television. Trying to switch input from Antenna 1 so kids can use XBox
Tries use the front or right side panel manual controls panel.Use the Channels buttons UP/DOWN push the channels UP button couple time.U should get in Video 1 or 2 which ever ur video game console hook in.Or your tv might just have a manual video button,put that u in video 1 or 2.Try website 1-800-remotes Factory original to buy an exact remote ur problem solved.None the solutions,help.
1helpful
Got the new wii sytem..came with 2 remotes. One works fine the other doesn't work. I put 2 sets of new batteries..nothing..put it in the dual charger only one works.. please help I have 2 kids and they're...
The Wii-mote probably just needs to be synchronized to your Wii. Open the battery compartment on the backs of your remotes and the front SD card slot on your Wii. Push the red SYNC button on the Wii and then the little red button on your Wii-motes (both of them) and they should sync to your console.
8helpful
My dish remote wont connect to the dish reciever
If you have a single mode receiver, you need to open the panel in front and push system info.
A channel number will appear near the bottom of the list of information... it may be between 1 and 15. Push the record button on your remote control. (the black button with the red dot). If the channel number changed, then your remote and receiver are not on the same channel. Assume your channel was #1. when you first pushed sys info. You need to program your remote to #1. On your remote, push the Sat button until all other top buttons light up. enter the digit 1 and then the # key. Press the record button 4 times. You have to make sure you have the correct color key inserted in the remote control. If you have a dual mode receiver, one remote key will be green, and the second channel remote will have a blue key. Go to the Dish network website tech portal ...Google will help you find it, for complete instructions from the horse's mouth.
Plays on wrong channel
ok i downloaded and read your DVR-1000 manual , this is what you will do .
While the DVD+VCR is turned off, press and hold CHANNEL (up/down) button on the front panel for about five seconds.
The unit will turn itself on and “RF 03” or “RF 04” appears on
the front panel display
Use CH ( up / down ) button on the front panel or CH ( up / down ) button on the remote control to change the RF output
channel (CH 03 or CH 04).
Turn the DVD+VCR off and then on
Set the TV to channel 3 or 4 depending on the RF
output channel you selected.
Now you can watch the DVD+VCR playback on CH3
or CH4 of your TV
PS , you should see a child lock button on the remote , if you press that button , you will disable front panel button controls so kids can't change anything , press it again to unlock that feature , it might come in handy.
Thanks for using Fix Ya .
J5
1helpful
4answers
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
