I've got a Switch D-Link DES 3226, I've lost Username and Password for login to configure the device. There is not reset button on the Switch, so I can't do anything to resolve the problem. How do I recover or factory reset it?. Give me solutions, thank you!.
How do I use the reset the password on my DES-3226?
I you lost your password contact D-link technical support and have your serial Number and MAC address and they could generate a Backdoor password for you.
Facing the front of the switch, the Reset pin hole will be to the very right. Insert a paperclip into the hole, press and hold the Reset button for 10 seconds. The device should now be at factory defaults.
My previous post was based on the *L* version, the only info I could find on the US site. And no I haven?t physically seen one until today since I use HP switches pretty exclusively. At any rate I did some more searching and found an overseas D-link site by accident. It didn?t have a manual but it did have a PowerPoint presentation on how to reset the switch without the web interface. Apparently the *L* version added a physical reset switch to avoid having to use the console, after you use it you?ll understand why. HP switches have a console connection as well; the problem with them is getting a program called HyperTerminal to work with the equipment.
Please note you need to connect the switch to a PC serial port using a cable that originally came with the switch. It looks like a standard serial cable with a DB 9 connector each end, probably with D-link molded into the connectors or on a label. Here are the instructions pulled from the presentation:
-Start the Hyper Terminal program (Windows XP: Start, programs, accessories, communications).
-Key in the [Username] and [Password, the default is no username and password.
-Select the [Reboot] option
-Select the [Reboot & Load Factory Default Configuration] option.
-Select the [Yes] option.
-You should see a counter running (on the left hand side).
-You should see a message on ?the switch is rebooting? (on the right hand side).
-You should see the above screen while the Switch reboot.
-When the reset is done you will be back to the [Username] & [Password] screen.
I have lost my HP KVM 16 port possword and no hyper terminal communicate so how can i access KVM possword
Not sure if you have seen a des 3226, but no pinhole on it! Still trying to find one.
I've got a Switch D-Link DES 3226, I've lost Username and Password for login to configure the device. There is not reset button on the Switch, so I can't do anything to resolve the problem. How do I recover or factory reset it?. Give me solutions, thank you!. my mail id is santosh[email protected]
I've got a Switch D-Link DES 3226, I've lost Username and Password for login to configure the device. There is no reset button anywhere on the Switch, so I can't do anything to resolve the problem. How do I recover or factory reset it?. Give me solutions, thank you!.
yes i am also so some problem plz told what is the solution
