If the cell phone battery is more than 3 - 4 years old thenthe battery could be worn out. Rechargeable batteries have a finite number of chargeand discharge cycles and will lose their charge capacity over time, i.e. won'tcharge to 100% and gradually the charge reduces until the battery won't chargeup at all. OR The battery shows a 100% charge but when the adapter isdisconnected the battery drops off to zero capacity in a very
Thanks Chris.
Exactly battery shows 100% charge but discharge quickly.....may be it's due to battery problem but my cell phone battery is 1 nd half year old..
Is there is any connection b/w hardware or cell battery?
well once again thanks!!!
There could be a fault in the cell phone and it is drawing excessive battery current or the battery is faulty.
See if you can borrow a good battery and use it in your cell phone. If the battery does not last more than 30 mins then the cell phone is faulty.
SOURCE: samsung corby GT-S3653 how to change default message storage
how to change default message storage location in samsung corby GT-S3653 because it is showing sms memory full after 200 massages even it is having 500 storage capacity
SOURCE: how to switch off the auto lock of the touch during call
this feature in Corby helps in preventing any unwanted actions in touch screen ; but it can be removed go to settings keypad settings and select to your need
SOURCE: My SAMSUNG CORBY TXT (GT-B3210)
Phones when plugged into laptop will terminate any sim card functions such as making calls to prevent data loss if a transfer is taking place.
This is normal and always happens there is no way to disable it just make sure you only plug it into your Laptop when you require to transfer files to phone or use the manufacture software to perform an task which requires it to be plugged into laptop..
