This website www.reliable-store.com has the
largest collection of repair, service, parts manuals of any vehicle on earth. Best website I came across for manuals.. Also have live assistance
With the advent of apps by Google, Facebook and Amazon, every other Smartphone user is amazed with the news that spread like a fire worldwide in spite of looking for the loopholes hidden behind the screen.
As many apps can't work without demographic location, the same case applies with these giant search engine, shopping as well as social media app, They keep tracking the users to find essential details what they actually do as well as their likes and dislikes. Upon collecting data, they display advertisements as per the data stored by them. Facebook, Amazon and Google track feature is encapsulated with coding that store each and every activity of yours and start displaying ads whenever you rush to any online store.
make sure you have the right bulb match your old bulb with one at Walmart, if metal prong is bent too far in get small screwdriver & gently pry up so that it makes better connection
Look at my store if you collect Coins or need a Great Gift for Anyone
If you have access to a 'smoke test machine' this will enable you to detect and locate the leak. If UV sensitive dye is also in the oil that creates the smoke for the smoke test, you can trace it with the UV light that comes with the machine.
Go too any auto store and get a leak detecting solution usually UV which willcome in a charging canister, then install following directions, when you shine a UV light on the areas your leaks will be shown thru the dye in the solution. That will locate the leak for you.
check out the housing for the thermostat...check out the heater hoses where one connects to the thermostat housing, the other to the waterpump....just replaced one on a honda that was pin hole sized and nearly impossible to see....also check headgasket and intake manifold gaskets...good luck
you will need a complete inspection of your leakage. A dye is sold at auto parts store that will mix in with your anti freeze. Then you will need an ultra violet lamp to shine on to the engine. The lamp will show were the leak(s) are coming from for the dye will glow from the uv lamp when turned on
It seems that you have a leak, best bet is to bring it to someone with a set of gages to check the pressures while the ac system is operating. The high side should be about 150-200 psi and low side between 30-40psi with those numbers you should be running very cool. If its not that high then you most probably have a leak in the system most probably at one of the recently replaced parts or a new place, fill the system with a uv dye and recharge. drive for a week or two and check with a uv light.
You can purchase a leak detection kit, which consists of UV goggles and UV light.(black light). You would have to pump some refrigerant from a bottle that has die inside with the refrigerant. They sell those at any autoparts store. You can pump some in , run the AC and check/look with the UV gogles and the light as to where the die is coming out of. With the goggles the die will show flourescent green. Thats, where the leak is. Or you can go to a garage/dealer and they will charge you about $100-$150 to do the same thing. (except they will inject the die with a specialty tool and than look for a leak) Some of the cans of R134 from store have die inside of them already. Read the can label. (the UV die will not hurt the system at all). The UV goggles and the light will run you about $40-50??. As far as repairing the leak, it could be potentially costly or it could be just a o-ring. You will not know until you pin point the leak with the UV die. O-rings are cheap, but something like the AC condensor could be $500. If you saing that the you can hear it in the front of the engine, it could be the condensor which is the radiator looking piece in front of the radiator. You can see it through the front grill, that's the condensor. Like I said, pinpoint the leak and make decisions from there. Let me know how you make out with that. Good luck.
