Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
terry herl Posted on Apr 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony kdf60xbr950 Having the same problem with no picture. Green lights blinks first then the red lamp light. My first thought is the lamp. Then I had talked to a tech and he tried to tell me that its the balist or the power supply and likley not the bulb? Has anybody else been throught this and what was the outcome. This is the original bulb with only about 1000-1500 hours on it ? was working fine one day and the next this ?
Anonymous
Level 3:
Top Expert:
  • Sony Master 14,553 Answers
  • Posted on Apr 13, 2012
Anonymous
Sony Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2714788
Points
48227
The problem here with the lamp is it has an average 2,000 hour life--only way for a "tech" to know if it is the problem is to replace it.
The ballast is the power supply for the lamp---lamp goes bad a lot more often than the ballast= sounds like the tech wants to create a shop repair..........
Sometimes the lamp will provide a warning by being dimmer just before it fails and sometimes not.
The lamp is customer replaceable(owner manual and You Tube have written and video instructions for most models).
You if change the lamp take a gamble--either it fixed the problem or not--Any shop or expert who tells you to replace the ballast first without even trying another lamp (10 minute job) is feeding you a story for lack of another expression.
Testimonial: "Thanks for all the input. I thought the same thing about the tech just trying to set me up. i'll replace the bulb and see what happens."
rcrump
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 23, 2019
rcrump
Contributor
Level 1:
Answers
Questions
0
Helped
19150
Points
14
I kept having this problem every three years or so. 60 inch Grand Wega would switch off (picture and sound) and switch back on. Each time I solved it with the purchase of a new lamp (XL2100U - instructions for replacement were available in pdf online, and there's probably a youtube video somewhere).
Well... A couple of weeks ago, it began doing the same, like clockwork, three years from my last purchase date. But I saw someone's comment here in Fixya about blowing dust out the back of the lamp.
So I got my air compressor and blew air through the plastic grill work that forms the box shaped housing behind the bulb, and through other openings, then popped it back in.
It hasn't cut out SINCE. And luckily I kept the older bulb too. So try this before you run out to buy a replacement bulb.
5 Related Answers
Anonymous
  • 150 Answers
  • Posted on May 29, 2009
SOURCE: Sony KDS50A2020 Blackout
Replace the lamp, clean the fans, seen it a hundred times, I know "the lamp light isn`t blinking" replace your lamp and you`ll be back up & running, gl, video-tek
Anonymous
  • Posted on Nov 26, 2008
SOURCE: Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Anonymous
  • 10594 Answers
  • Posted on May 30, 2009
SOURCE: XL 5200 bulb replace and NO Picture or Sound
3 times blink error code shows Lamp Door is not seated / fixed properly, please recheck it and make sure that door close safety switch is pressed as this switch sends error signal to system control chip.
Anonymous
  • 5 Answers
  • Posted on Sep 09, 2009
SOURCE: power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Anonymous
  • 68 Answers
  • Posted on May 19, 2010
SOURCE: flashing red light saying lamp and no picture.
REPLACE LAMP !!!
Buy an Orginal Replacement Lamp.
I have a sony kdf 50e-2000 the green light goes on then it goes to thr red blinking lamp light. I have no sound or picture. If I replace the lamp light will I get sound and a picture again?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
For a new Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
2helpful
3answers
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
5helpful
2answers
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
2helpful
Red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
1helpful
3helpful
4answers
Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
Symptom shows that TV needs Lamp replacement.
Sony TV Lamp is available in Part Store and lamp replacement procedure is written in user manual of TV.
Sony- KDF-50E2000
Have you replaced its Lamp?
Symptoms shows TV needs new lamp.
Please always buy original Sony lamp for replacement.
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
