DeLonghi Stiromeglio Compact PRO 300 Iron Logo
A
Anonymous Posted on Apr 12, 2012
Blow a fuse?
Can the iron blow a fuse? My iron quit steaming so I ran water + citric acid through it an it worked like a charm. When I was running more clean water through it it all of a sudden just quit working all together. No lights. Nothing.
1 Related Answer
barry miller
  • 47 Answers
  • Posted on Oct 02, 2011
SOURCE: delonghi steam station iron wont take water pump
this sounds like a blockage to me have a good look, good luck
Hi my iron where the water goes in is steaming and whistling. Can you help me? Thanks Jacqueline
Sounds like a seal has blown.
Time for a new iron, I would say.
Aug 05, 2021 • Irons
tip
How to Descale your Iron.
To Descale your Iron, use Scale Away, CDR, you can buy at the hardware. It will remove the deposits. After you get it descaled you need to use Distilled water that you buy at the grocery store in it. This will avoid it scaling again.
Also, Vinegar and water, Citric Acid crystals, Usual dose 1 teaspoon per 200ml water works
Pour it in just like the water and let it steam out, then repeat with water, steaming out over a rag, sheet or something.
on Feb 13, 2010 • Irons
Water coming out of steam holes
Either: the iron is not hot enough to heat the water to steam temperature or the internal water-flow valve is leaking so that too much water is getting through. Check the iron is getting hot enough first. If it is then run some de-scaler (as used in kettles) through the iron to try to clean all the passageways. Always ensure that you fully re-flush the iron after de-scaling or you'll damage your clothes with any acidic residue left in the iron.
Good luck.
Dec 04, 2016 • Irons
I have a EURO-PRO X Model EP965 Steam Generator seems to working but steam is not coming our, neither for the iron nor for the brush.
I think you have a tank that is calcified and is not getting enough heat to the water assuming there is enough water in it. If it was blocked it would either cause the relief valve to vent or explode.
I would start by cleaning it, my best guess would be to run a few cycles with vinegar in it. This is a mild acid that will dissolve the calcium deposits. Try maybe a 50%-50% with vinegar and water.
Be sure the vinegar will not damage the unit, I do not know.
Hope these links help.
http://www.sharkclean.com/manual/EP965-instruction_book_0701A.pdf
Euro Pro EP965 Use And Care Instructions Manual
Euro Pro EP965 Carpet Cleaner User Manual
Questions Answers for euro pro steam cleaner iron
Water distiller keeps shutting off
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat.and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle .
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Test the heating elements and power for blowing fuse.use the DVOM
God bless you. see the diagram 2_6_2013_8_23_01_pm.jpg2_6_2013_8_23_30_pm.jpg
Feb 06, 2013 • Irons
4helpful
As the steam builds up it constantly comes out of the the blow off pressure valve under the iron. steam will come out of the sole plate when the button is pressed
see this causes and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Oct 02, 2012 • Irons
6helpful
2answers
The steam is building up in the water tank but not going through to the iron.
I suspect that the discharge holes have become clogged by calcified deposites due to hard water. You need to de-calcify the iron. Mix one cup of white vinegar with one cup of water and pour this mixture in the iron and let it heat up. The acidic vinegar should dissolve the build up. repeat until clear. forthe final, use a little lemon in a cup of water to get rid of the vinegar smell. You can prevent this by using only distilled water in the iron, but this is not really practical, so a couple of clearing runs of the vinegar/water bath each month will put this off.
2helpful
I have the vertical commercial steamer model IS 8100. Machine lights up, no steam. The cord doesn't even get hot. I've tried to demineralize it by allowing vinegar to sit in the well of the base. Thanks...
My unit did the same thing. There is a temperature fuse attached to the heating chamber. If the unit overheats it will blow this fuse. It is not re-setable and must be replaced. Radio Shack carries these items.
Check your chamber for crude. Mine was pretty bad and I ended up filling it up with white vinegar over night. If you can get it to work, boil a solution of 1/4 white vinegar and DISTILLED water. Let it run through a whole tank of it and then run it with just DISTILLED water until you don't smell vinegar anymore. Do this every few months with heavy use.
Low steam due to clogged vents
Only clean your Rowanta 980 with clear filtered water only. The unit comes with a small hose and faucet adapter to flush the steam tank thru the threaded plug when cold. Do not use hard tap water, that is where most of the mineral deposits come from. The other is storing the iron with water in it without purging all steam/water tank dray. Do this several times running dry with the burst of steam over towels to blow as much of the stuff out as possible. A new sole plate will cost close to $90 or so if you want to replace rather than clean it.
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: [email protected]
Hi, ive lost my instructions and need to descale my iron. could you please advise me how to do it many thanks jo
CDR, Scale Away, you can buy at the hardware. It will remove the deposits. After you get it descaled you need to use Distilled water that you buy at the grocery store in it. This will avoid it scaling again.
Pour it in just like water and let it steam out, then repeat with water, steaming out over a rag, sheet or something.
Top DeLonghi Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a DeLonghi Iron Expert? Answer questions, earn points and help others
