Help ,me pleas my e mail is [email protected]
SOURCE: I can't install my Creepnight
The Windows 7 should automatically convert compatibility for software, but to force compatibility manually:
1. Right-click the installer, and go it's properties (this is the last option in the drop-down list).
2. Click the compatibility tab
3. Check the compatibility mode box and select the option from the list that matches the operating system you know the game last worked on.
4. Apply the changes, press OK, and re-run the installer.
SOURCE: Umax Scanner Astra 4100 Drivers for Window Vista
required umax astra 4100 scanner driver for vista/win2003 server
SOURCE: I want to install Windows 7 on my laptop, it
If you are updating from Winos XP orsome higher version to Windows 7, an automatic update is run which backup allthe data, installed files and saved application settings.If you freshly install Windows 7 inyour PC, it will remove all the installed applications and saved settings.
